Serpentine bracket removal
Old Oct 20, 2008 | 08:11 PM
Jammin'Trey's Avatar
ok, Im swapping in a sbc 350 soon and will have to take off my old 305 brackets from the motor. i know I need reverse torx sockets and torx bits but I am confused on how I am going to leave the p/s pump in the car when i swap brackets? It looks like there is a bolt that holds it to the block that goes through the pump too. and to get to that bolt I woul dhave to remove the pump pully seems like a lot of work.
Old Oct 21, 2008 | 09:09 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: Serpentine bracket removal
Don't fight with the pulley if you don't have to.
I left the pump bolted to the bracket, disconnected the hoses, unbolted and swapped the whole assy to my "new" engine. It was easy.
Tip:
If the torx head bolts are too tight (mine were), don't strip the head. Take a punch that fits inside the star and whip it with a hammer.
Old Oct 22, 2008 | 09:01 AM
cool, I will just buy a new high pressure line, one without that stupid a/c pressure switch. Thanks man.
Old Oct 22, 2008 | 11:51 AM
89RESTO's Avatar
2011 Norwood Gathering
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
Why does your power steering pump have a high pressure a/c switch?Perhaps your thinking of your a/c compressor.
Old Oct 23, 2008 | 09:03 AM
Theres a switch that cuts ac comp. under high p/s load.
Old Oct 23, 2008 | 11:29 AM
89RESTO's Avatar
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Got it, as supervisor42 says just leave the pump on until you remove the bracket.
83 Crossfire TA
Jan 3, 2016 01:26 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
