Rocker stud taps break through?
Old Oct 22, 2008 | 09:29 AM
AC's Avatar
AC
Car: Used to drive a camaro
I just got my Dart aluminum heads in. I've never taken the time to look at other heads but I did this time. There are a few (more than half) of the rocker stud taps that break through what I believe is the cooling channel/jacket of the head. My first thought is that is an issue. Second thought is RTV or teflon tape??? Comments?
Old Oct 22, 2008 | 09:37 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Do you mean the bottom of the hole, or the side of the threads?
If the bottom of the hole, look inside the intake ports while shining a light into the stud hole. Do you see light?
Liquid Teflon sealer would be my recommendation.
Old Oct 22, 2008 | 10:20 AM
AC's Avatar
AC
Re: Rocker stud taps break through?
Bottom of the tap. The pilot hole, not the threads themselves. Is this normal?
Old Oct 22, 2008 | 02:51 PM
AC's Avatar
AC
So I confirmed, some of the taps pilot holes are breaking into the intake ports. This is apparently a normal occurence. Silicone sealer is the recommended application on the rocker arm stud threads.
I guess, live and learn
apie2546
Oct 16, 2016 02:24 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
sjorgens
Oct 1, 2015 07:54 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
