(Build) Will these work together
Old Oct 22, 2008 | 03:45 PM
skyhigh4by's Avatar
Car: 2004 GMC 2500HD
Engine: Duramax LLY
Transmission: Allison
Until I do a auto-man swap Im gonna run a 700R4. Stock 350 bottom end, Vortec heads, Comp cams XE268H complete kit with lifter springs and all, Speed Demon 650 and a dual plane intake of choice. First off does this sound like a decent combo? To run this cam do I have to have an 87+ block? And will those springs work on the Vortec heads? Thanks for any input, if Im stupid and made bad choices please speak up!
Old Oct 22, 2008 | 03:58 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: (Build) Will these work together
As far as I know, that cam is a hydraulic flat tappet. Therefore, you don't want to put it in an 87+ block (cause they use hydraulic roller cams).
Old Oct 22, 2008 | 04:27 PM
skyhigh4by's Avatar
Engine: Duramax LLY
Gotcha, thanks for the heads up. If thats the case then I will have an easier time. As I read more into this Im unsure of intake. Can someone suggest a good intake to match that cam. I was thinking edelbrock performer EPS because it works with the vortec heads.
Old Oct 22, 2008 | 06:00 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Performer RPM.
I have an xe268h with lifters collecting dust in my garage. used for about 1000 miles, lifters matched to lobes. Let me know if you're interested in saving a few bucks.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
