Coolant
Old Oct 23, 2008 | 04:06 PM
gtpro700's Avatar
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
Coolant
When firing up an engine for the first time how do you guys go about filling the coolant to proper way? If you fill the radiator up at first should you leave the cap off so when the thermostat opens you can add more then? or will you have problems with the cap off running the engine between 2000-3000 rpms with it overflowing and splashing everywhere? If you could tell me the procedure you usually go through that would be awesome also what psi radiator cap should I run?
Old Oct 23, 2008 | 04:38 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Coolant
Fill the overflow tank, fill the rad, leave the cap off, start the engine, continue topping up the rad while the engine warms up, put the cap on when coolant starts to expand and overflow from the filler neck. Use a standard 16 PSI cap.
Old Oct 23, 2008 | 07:58 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Re: Coolant
I drill a 1/8 hole it the stat so the air can escape.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
