WHERE/WHEN Does the smog pump/valve send air?
Old Oct 23, 2008 | 05:19 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
You've got 3 options....atmosphere, manifolds, and cat. From the factory, where is air being sent under what conditions?
Old Oct 23, 2008 | 05:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Open loop - manifolds.
Most closed loop conditions - cat.
Some closed loop conditions (deceleration, I understand) - manifolds.
Old Oct 23, 2008 | 07:26 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: WHERE/WHEN Does the smog pump/valve send air?
That seems backwards to me. I would think at open loop the air went to the cat to heat it up quicker.
Old Oct 23, 2008 | 07:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
In open loop it goes to the manifolds for better mixing, better burning of leftover hydrocarbons, and because the ECM is ignoring the O2 sensor anyway.
Old Oct 23, 2008 | 07:57 PM
five7kid's Avatar
A.I.R. existed before 1975, when catalytic converters became mandatory. It always went to the manifolds, right at the exhaust port exit. That's where the exhaust gases are hottest, and the reaction is most effective (other than the cat, that is).
We used to have a full-size '84 Chevy van, which did have a cat. It had an open-loop q-jet, so no O2, and the A.I.R. only went to the manifolds - no tube to the cat.
Ghettobird52
Jul 5, 2024 11:18 PM
stalkier
Dec 6, 2015 11:25 PM
mike40sm2
Sep 1, 2015 02:15 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Aug 24, 2015 06:52 AM
jackhammer
Aug 15, 2015 10:04 PM
