please help
Old Oct 24, 2008 | 12:05 AM
mike08's Avatar
Want a title? Post!
please help
My name is mike i have a nice oil leak on the back left side of my motor.
Old Oct 24, 2008 | 06:33 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: please help
nice advice kingpin . mike , a little better info. on location would be good . if it's high up on eng. , good bet its valve cover gasket . if it's under exhaust manifold good bet it's oil press/fuel sensor . sensor is located just fwd. of oil filter .
Old Oct 24, 2008 | 06:52 PM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
Re: please help
lol good advice. "Take it to a shop". The point is to avoid going there.
Old Oct 24, 2008 | 06:58 PM
UNCLE TOM's Avatar
Re: please help
my point is made .
Old Nov 26, 2008 | 10:44 PM
allenfre's Avatar
Re: please help
Yeah it's better to learn than to spend a couple of bucks over & over again going back to these "reliable' shops.
Old Nov 28, 2008 | 10:32 AM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
Re: please help
Could also be where the distributor goes through the intake. I had a nasty leak there once.
Old Nov 28, 2008 | 11:41 AM
LMSkyliner's Avatar
Car: 1989 Iroc-Z
Engine: 383 FFI
Transmission: TKO600
Re: please help
lets see. My engine had some bad oil leaks when i first got it. When i opened the hood the smoke was coming from the passenger side. It ended up being a combination of things. First, my rear main seal was junk, but that was clear by all the oil splashed around the back of the engine when you look underneath. The second, and what it sounds like for you, was that the valve cover gasket was leaking in the back.
