305 heads vs 305 tpi- tbi heads
Old Oct 24, 2008 | 11:38 PM
basiccamaro's Avatar
Ok, I lready know that switching to a 350 is a better deal than running a 305. But I do not want to change out the entire engine in my '83 with the plain 305 with perimeter valve cover bolt heads.
So my question is, are the newer center bolt valve cover TBI, or TPI (?) 305 heads (I'm assuming they are center bolt valve cover heads) from an IROC any better performers than the older, plain 305 heads? Are they all 58cc combustion chambers? Is it worthwhile trying to find a set of FI 305 heads for a mild engine hop up? If so, are there any special casting numbers to look for? Do you have to also go to a Vortec style intake manifold? I just want to warm the engine up a little, it's NOT going to attempt to be a race car, I just want to increase the fun factor a little over the stock smog dog, but I don't mind changing over to a Vortec manifold and center bolt valve covers if I need to. Thanks.
Old Oct 24, 2008 | 11:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 305 heads vs 305 tpi- tbi heads
Swirl-port TBI heads of any vintage are to be avoided. Your existing heads (LG4?) would be fine. There's no performance difference between center-bolt and perimeter bolt heads.
Old Oct 25, 2008 | 12:22 AM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
True that. I have a 350 with my LG4 center bolt heads from the original 305. They work just as well as the 350 heads. The center bolt valve covers came into affect in 87 for all chevy V8 engines. So if you keep the heads you have on there, you will probably be fine.
Old Oct 25, 2008 | 12:30 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Better, usually... you don't give up compression.
xkingcodex
Feb 12, 2020 07:43 PM
gta90
Sep 15, 2015 04:00 PM
dutch930
Sep 11, 2015 06:58 AM
st.evel07
Aug 13, 2015 06:15 PM
