QUESTION ABOUT MY 1987 TRANS AM
Old Oct 25, 2008 | 10:55 AM
OFFYTWIN's Avatar
i just picked up a 1987 trans am orig. came with a 305 tpi but motor was swapped out to a 350 tpi it has a tpis big mouth intake on it, looks like aftermarket injectors and sounds like there is a cam , car has been sitting for about 3 years car starts up however the idle jumps all over the place im going to do a tune up on it however the check engine light is on and it comes up that the map sensor is bad i have looked every where under the hood and i cant seem to find it can anyone please tell me where it is or show me a pic of where it is also looking to find a pic of the vacuum hoses because when the car is running there is a vacuum leak ang i cant seem to find where this hose goes to, also there is like a air box located on the pass, side of the engine next to the heater control valve that makes a racket when its running with no hoses going to it
Old Oct 25, 2008 | 09:53 PM
84transam87's Avatar
Re: QUESTION ABOUT MY 1987 TRANS AM
check out autozone.com they have a troubleshooting section and also somewhere in there a parts locator. you enter you car and year and what part your trying to find and it tells you where on the motor it is. how accutate it is i do not know but always worth a try. good luck
Old Oct 25, 2008 | 11:45 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
If you have a Mass Air Flow sensor, you will not have a MAP sensor. That code also goes for the Mass Air Flow sensor. Check your MAF relays (there are 2 of them by the fuel pump relay on the driver side next to brake booster). If those are ok, you may have a bad MAF. Also, the Chiltons book has the vacuum diagrams in there. If you put a picture of the hose and the engine, we might be able to help with that.
Old Oct 26, 2008 | 06:03 PM
OFFYTWIN's Avatar
thank you guys the info was helpful, i found out i dont have a map sensor, it is a maf sensor that i do have..
birdtojag:: question i have where exactly are these relay's? and is there anyway i can find out if they are bad?? thank you
84z96L31vortec
Aug 20, 2017 12:16 AM
beachrodder
Aug 25, 2015 08:05 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
jahblah
Aug 12, 2015 05:54 PM
