holley systemax II
Old Oct 28, 2008 | 09:01 AM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
holley systemax II
Will this kit work with my l05 short block? its not the factory one its a gmparts shortblock i think its a 4bolt main and flat top pistons thats all i know for sure does anyone have this kit?
Old Oct 28, 2008 | 02:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It'll work. Is this the roller or flat tappet cam version?
If the pistons are stock Goodwrench, they'll be dished with valve reliefs.
Old Oct 30, 2008 | 09:11 AM
Car: Camaro RS
Re: holley systemax II
its roller but are you sure they have valve releifs? If they dont how much are the pink rods?
Old Oct 31, 2008 | 01:16 AM
five7kid's Avatar
Exactly what GM engine is this? "gmparts" doesn't really match anything I've heard. I assumed "Goodwrench", which is a "service van fleet" type replacement engine. GM Performance Parts is a slightly different story, but most of them still had pistons with at least a slight dish.
Old Nov 2, 2008 | 04:39 PM
Car: Camaro RS
i meant gm performance parts but it is just the block that got replaced
Old Nov 3, 2008 | 01:17 PM
five7kid's Avatar
They typically had pistons with dish/valve reliefs totaling about 12cc. True flat tops will have valve reliefs with totaling around 5cc. If there are no valve reliefs, it's full dish pistons, which are 20+cc.
Pink rods were replaced with PM rods sometime in the early 90's. PM's were cheaper and performed just as well as the pinks. ARP rod bolts are more important than pink vs. PM rods.
RaverRacerX
Mar 17, 2026 01:49 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
