Power steering pump needs bleeding?
Old Nov 2, 2008 | 01:47 PM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
Is it possible to bleed the pump.. i dont think i have ever heard of doin that. If so what is the easiest method? My car sat for six years and i finally finished my engine build. Replaced the old 3 belt setup with a serp so now I have air in the pump.. any ideas?
Old Nov 2, 2008 | 02:26 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
Re: Power steering pump needs bleeding?
turn the steering wheel back and forth 10 time and that should get all the air out, with the cap off. if not u might need a new pump. also make sure the belt has good tension
Old Nov 2, 2008 | 05:35 PM
Daves03's Avatar
Car: 1991 Chevrolet Camaro RS Red
Engine: 305 V8 TBI
Transmission: TH-700R4
at work we lift the front wheels off the ground and turn the steering back and forth a couple of times to prime/bleed the pump then start it and turn it back and forth to get all the air out, top off the reservoir and drive it to check operation.
Old Nov 3, 2008 | 01:35 PM
Copchaser's Avatar
great.. thanks for the tip
Glowsock
Jul 24, 2025 03:15 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
