How to calculate new duration with 1.6 rockers
Old Oct 28, 2008 | 12:12 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
It can't be the same as calculating lift - /1.5*1.6 is it?
Old Oct 28, 2008 | 12:14 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: How to calculate new duration with 1.6 rockers
You can't calculate a duration change because it depends on the shape of the skirts of the lobe.
Old Oct 28, 2008 | 12:27 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Oh, like how steep it is?
Old Oct 28, 2008 | 12:34 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Pretty much. There won't be any change in the duration measured at the cam itself of course, but if you're measuring duration between two lift points at the valve there'll be a very slight increase. Nothing to write home about.
Old Oct 28, 2008 | 01:52 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
From discussions with Competition Cams tech guys and what I have read the "effective" duration change is around 5' when going from 1.5 to 1.6 rockers. That is only an estimate because of the differance on ramp profiles from one cam to another, as has been pointed out. It's theoretically possible to measure it with a degree wheel but a PITA with hydraulic lifters and you'd have to measure it at the rocker tip and compare the before and after. So I just use 5' as a general guideline. When I did the swap, I figured my 212/218 CC was about 217/223, or about a half-step up.
Old Oct 28, 2008 | 03:06 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Total duration won't change but the .050 duration will increase very slightly due to the valve opening slightly quicker with the increased rocker ratio.
It's not a big enough number to make a noticeable change. I'd guess and say 3* max increase in the .050 duration, if even that.
Old Oct 28, 2008 | 04:58 PM
Car: 89 IROC
Engine: 6.8 HSR N2O
Well put and good to point out the differance in total and .050 duration. But isn't that about where it's agreed that flow begins? I suppose it varies some from cam profile to profile. And whether it's 3 or 5, it isn't much. But it is in the "right" direction depending on your needs. If you're wanting more flow, as would be expected by wanting more lift, it's more.
Old Oct 28, 2008 | 08:20 PM
AlkyIROC's Avatar
Car: 87 IROC L98
A roller cam with it's steep ramps will increase the .050 duration more than a flat tappet cam will with a rocker ratio swap.
Old Oct 28, 2008 | 09:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Other way around, the steeper the ramp the less change there is. Imagine the absurd case of a lobe with vertical sides, there'd be zero change in duration.
Old Oct 29, 2008 | 02:21 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
A typical hydraulic roller cam will show about 3 extra degrees at .050
Old Oct 29, 2008 | 04:10 PM
RedHawkLB9's Avatar
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
do you feel anymore power from it?
Old Oct 29, 2008 | 04:35 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
In playing with dial indicators and degree wheels, I've come to feel 2 degrees is most accurate. I've never played with a solid or solid-roller, however.
Old Oct 29, 2008 | 11:34 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
I was going to suggest this, degree wheel+dial indicator+excel will get you an answer.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
slowsi
Oct 18, 2015 08:49 PM
Jorlain
Oct 8, 2015 01:57 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
