Oil leak under passenger header
Old Nov 3, 2008 | 12:59 PM
plasmeh's Avatar
Car: 1986 IROC-Z
Engine: 360cu @ 10.5:1
Transmission: T56 - Pro 5.0
Axle/Gears: 4.10 - Zexel Torsen - Moser Axles
I have an 86 Camaro with a 350 and there is oil soaked everywhere just below the passenger header. There is no indication that it is the valve cover as there is no oil there and none anywhere above the header, just below it. It drips down and onto the starter. Trying to find the source, any help is appreciated.
Old Nov 3, 2008 | 01:15 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
Re: Oil leak under passenger header
i had the same prob, check the oil pan mine leaked all over my starter, check there
Old Nov 3, 2008 | 01:20 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Smog pump missing?
Old Nov 3, 2008 | 02:40 PM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
Distributor shaft?
Old Nov 3, 2008 | 04:17 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Originally Posted by naf
Smog pump missing?
He may be on to something, are you still running a smog pump? If not do you have a bolt in the appropriate hole so that oil isn't dripping out?
Are you absolutely POSITIVE it isn't a valve cover gasket? They can be tricky sometimes... other than that it's possible is leaking at the rear of the intake and dripping down there somehow.. or a head gasket leak.. crack, etc...
Old Nov 3, 2008 | 04:18 PM
TPeye's Avatar
Car: 1992 Camaro Z28
Engine: 350ci
I had a problem just like this. Check the dipstick tube where it goes into the block. I was able to seal mine with some gasket maker.
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 21, 2015 09:32 AM
Cameeeero
Aug 20, 2015 03:06 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
drathaar907
Aug 6, 2015 04:20 PM
