Trouble codes
Old Nov 5, 2008 | 01:42 PM
RedBravo's Avatar
Car: 85 TA
Transmission: LB9
Axle/Gears: 9.5:1 3.23
Trouble codes
Can anyone please help. My 85 Trans Am 305 TPI has been getting intermittant check engine lights. I had it tested and this is what came up.
Code 22: Throttle position sensor too low.
Code 32: EGR system problem. I have a bad solenoid so the EGR has been positioned to always be open.
Code 33: MAF sensor or circuit too high. "Replaced MAF this spring"
Code 43: ESC module or sensor circuit problem.
Can anyone please help? Thanks.
Old Nov 6, 2008 | 07:58 AM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
Re: Trouble codes
I would start by testing each of these components individually. Just to be sure.
BTW: with your EGR open as it is how does the car idle. I always thought that it wouldn't at all if the EGR were open.
I would also check voltage to each of these sensors. Most of the sensors should have 5V going to them with the key on. I know for sure that the TPS has this voltage. Can't say for sure on the others.
Old Nov 6, 2008 | 09:14 AM
RedBravo's Avatar
Car: 85 TA
Transmission: LB9
Re: Trouble codes
The idle runs good some days, and it runs rough others. I will check these things and see what happens. Hopefully I can get more insight. Thanks for the reply.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
Lmancha96
Sep 25, 2015 08:11 PM
