Installing Air Pump delete pulley
Old Nov 5, 2008 | 07:25 PM
69442DREAMCAR's Avatar
I posted in parts wanted and one of the members pointed out one on ebay. I bought and it arrived today. Noticed the pulley is smooth like it would be used on back side of belt. My air pump has the grooves like it rides on the inside of the belt. Also it looks like when bolted on it will be behind where my belt rides. The only picture I could find was a car with a/c. I need to keep my a/c in Louisiana. Any help or suggestions?
Old Nov 5, 2008 | 09:24 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
Re: Installing Air Pump delete pulley
you need to change the belt routing and use a different size belt for that pulley. there is a write up on this set up in the tech articles.
Old Nov 5, 2008 | 10:08 PM
Damon's Avatar
Forget the delete pulley- doesn't even sound like you've got the right one for a 3rd gen Camaro. Follow the tech article on this board instead. You simply remove the smog pump completely, buy a different length belt (96.8") and use a slightly altered belt routing. Done it on several cars now- it's a snap, costs nothing except the cost of the belt and it works just beautiful. No complaints at all with it.
Old Nov 6, 2008 | 09:51 PM
Anyone have pictures of belt routing without smog pump?
Old Nov 6, 2008 | 10:09 PM
89IROCZ28's Avatar
Car: 1989 IROC Z28
Engine: 305 TBI (L03)
Transmission: 700R4 w/ Corvette servo
Axle/Gears: 4th Gen, 3.23, posi, PBR
From Tech Articles:
https://www.thirdgen.org/serpentine
Old Nov 7, 2008 | 04:03 AM
kaitlin's Avatar
Car: 92 rs conv
Engine: 3.1
Transmission: a4
Axle/Gears: 3:42
took everything off mine hardest part was the torx bolts going thru housing other than that I used the same belt just routed it as in tech articles plenty of tension
Old Nov 7, 2008 | 06:23 AM
Thanks for posting the picture, after doing search last night I found it and added to my favorites. Make it easier to find. The top picture looks like the smog pump delete plate I got. Now it makes sense that the pulley is smooth instead of grooved. I will post this afternoon after I install it. My son will be here from Dallas and he will be able to post pictures.
Vintageracer
Jan 10, 2020 05:33 PM
italiano67
Dec 11, 2016 09:21 AM
krisner89
Carburetors
Sep 20, 2015 08:56 PM
mcquigg
Aug 13, 2015 02:26 PM
drathaar907
Aug 6, 2015 04:20 PM
