Need some Torque Specs
Old Nov 7, 2008 | 05:52 PM
Chaos2084's Avatar
I will be putting my motor back together either tonight or tomorrow and need some torque specs. I don't have a manual and don't feel like spending $19.99 on a chiltons at schucks. Unless it is really worth it? Anyways I need head bolt specs, water pump, and Rocker arm nuts with stock heads.
Thank you.
Old Nov 7, 2008 | 05:57 PM
badazta87's Avatar
Car: 87 GTA
Engine: Under Construction
Axle/Gears: 3.70:1
Re: Need some Torque Specs
torque the water pump to - T- for Tight!
Old Nov 7, 2008 | 06:06 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Of course, it's worth the money, especially if you continue to work on your car. Better than relying on someone else to provide you with the info you could have at your fingertips.
JamesC
Old Nov 7, 2008 | 06:10 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
rocker arm nuts? this is a hydraulic cam, you do it to lash.
water pump uses 3/8NC bolts, call it 35ftlbs or so.
that's about "tight".
Old Nov 7, 2008 | 06:12 PM
badazta87's Avatar
Car: 87 GTA
Axle/Gears: 3.70:1
I believe the cylinder head torque is 65 ft lbs in 3 steps..
Old Nov 7, 2008 | 06:19 PM
Chaos2084's Avatar
Thanks. I guess I will just go buy it then probably be really usefully. Thank you for the replys so quickly.
The studs are installed into the cylinder head then the rocker arm goes over the stud then theres a bearing sort of thing that goes inside the rocker arm then a nut goes over it to hold the rocker arm in place over the Valve spring. It's all stock I guess.
no green
Jan 9, 2016 09:22 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
