Convert or Not?
Old Nov 7, 2008 | 06:20 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Convert or Not?
https://www.thirdgen.org/tpi-sfi-mpfi-tbi-cpi
In the article I'm trying to figure which would be best to go to.
I have a 1989 camaro rs 5.0 tbi, which would be best to go and convert over to? What will I need to convert? Is it worth it? (my gains i'm looking for is more power)
regards,
Timinsk
Old Nov 8, 2008 | 10:41 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Convert or Not?
more power? you'll need to be a bit more specific. If all you want is another 20-30 horses, then the TBI you have is fine. In fact, the right TBI setup can support over 350 crankshaft horsepower.
Before worrying about this, start with a cat-back exhaust, headers, and a change of axle ratio. That'll give you a noticeable improvement, and help get the car ready for more power. Then decide if you want to struggle along with a 305, or get a 350. Decide how much power you will be happy with.
If you're gonna stay 305, and not use Vortec heads, then Edelbrock has a TBI intake, but it won't be that impressive until you replace your swirl-port heads with something better. With TPI heads, that intake swap will get you at least 20 HP at 5000 rpm.
Holley makes a 670-cfm throttle body, much like the factory TB used on the 454.
If you go to Vortec heads, GM Perf Parts has a TBI intake.
JET offers an adjustable fuel pressure regulator. You'll want to find an L69 dual-snorkel air cleaner.
All the above mods apply whether you stay 305 or go 350.
Old Nov 8, 2008 | 01:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Bottom line: None of those is more "powerful" in and of itself than the others. The difference is in the "supporting cast" - heads, cam, exhaust. After that you could argue absolute air flow, when aftermarket intakes come into play. Regardless, the TBI is the weak sister from the factory in "supporting cast".
Old Nov 9, 2008 | 08:05 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Re: Convert or Not?
For now i'd like to stick with my 305.
This weekend I'm going to send my camaro in for getting a catback 5 but a slight bigger than stock factory and a new catalytic converter.
So after that would the following as you stated make a noticable improvement?
axle ratio (is this ring & pinion?)
juel regulator (50 psi fine?)
Dual Snorkel (why not just a open element?)
Anything else I could do that would improve my power?
"Weak" is a word you used. Meaning that its just the supporting cast that is; correct?
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
