Replacing a single rod bearing?
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Hey Everyone.
Im going to be putting my motor back together. The engines original bearings only have about 10k on them and their mint, so im planning on re-using them.
However, one of the bearings i dropped and theres a score on the face now.
If i use the original bearings on 7 rods and new bearings on 1 rod, will it matter? Will i have assembly issues?
Also, should i be using assembly lubricant on the bearing faces when i install them?
Thanks!
Thanks!
Car: 85 camaro z28
Engine: 305 but i got a '70 350 LT1
Axle/Gears: 3.08
Re: Replacing a single rod bearing?
you need to put lube on the bearings when building the motor, as of t he bearing question im not 100% sure but i would play it safe and replace all the bearings.
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Perfect! Just means $5 vs $40, doesnt seem like much, but as a broke 18 year old despirit to drive his car again its money i dont have haha.
The motor will get about 6 - 7k put on it before i tear it apart for forged pistons, rods, bigger cam, CNC heads etc etc.
As for bearings, i know i need to lube them, for the LS1's i read that alot of people juts put 30 weight oil on the bearings and assemble it all but i wanted to play it safe and i figure the assembly lubricant is tougher and thicker and will be best for my first start up with it.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you don't have the money to do it right now, when are you going to have the money to do it over again?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Single bearing is fine but you should plastigage it to make sure the clearances are the same since it will probably come from a different batch. Chances are there will be no difference.
I coat all my bearings with Luberplate assembly lube when I put them in.
ambainb
Apr 25, 2016 09:21 PM
red90IROCls1
Aug 25, 2015 06:56 AM
