What is this switch/sensor?
Old Nov 8, 2008 | 04:24 PM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
I may have asked this in 2002 when I did the intake manifold gasket back then. This (in the thick white circle in case you missed it) plugs into the front of the manifold and in my case, the connector is broken. Any help on what this does/is called would be a great help.
Attached Thumbnails What is this switch/sensor?-im.jpg
Old Nov 8, 2008 | 11:08 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: What is this switch/sensor?
Water temp sensor. It is for the ecm. (Not the gauge in the dash) Checker or autozone has it.
Good luck!
Old Nov 8, 2008 | 11:18 PM
Daves03's Avatar
Car: 1991 Chevrolet Camaro RS Red
Engine: 305 V8 TBI
Transmission: TH-700R4
as brittle as they get it would have probably snapped when you reconnected it.
Old Nov 9, 2008 | 02:50 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
88 IROCZ; The one on the left is the cold start injector switch, the right is the coolant temp sensor for the ECM.
What is this switch/sensor?-cts.jpg
Old Nov 9, 2008 | 08:08 AM
Damon's Avatar
Yeah, the one with the rectangular connector is for the cold start injector, the one with the oval head is the coolant temp sensor for the ECM.
