Marvel Mystery Oil
Car: '83 Firebird S/E
Engine: The Chevy 305. with carburator
Transmission: 700R-4
Marvel Mystery Oil
I cannot give enough praise for this product
After just 250 miles, the 4 quart 20W50/ 1 quart MMO mixture has done its job. I wasn't certain if it was working at first, as the noise actually got much louder and more consistent, before it simply disappeared. Now I have a quiet engine, without so much as a whimper from any of those pesky hydraulic lifters. This stuff will stay until spring, at which time the new oil change will be the same exact wonderful-smelling mixture, unless you mechanics believe that the oil has too much removed crud to wait until April, '09.
Thanks Everyone.
Seth
Thanks Everyone.
Seth
Transmission: 4L80E/4L80E
It can wait until spring as long as you don't plan on driving it until then.
Otherwise, change the oil & filter a little sooner than normal to get the loosened stuff out of the crankcase.
Re: Marvel Mystery Oil
It is an everyday driver.
I will do another oil change this month.
No more Fram filters, only K&N.
Thanks Again,
Seth
Thanks Again,
Seth
skinny z
Oct 5, 2015 06:23 PM
