i need a cam for a .30 over 350
Old Nov 12, 2008 | 12:06 PM
dioismyhero's Avatar
hi i am looking for suggestions for a camshaft, i'll tell you what i got so far! i am looking for the "best bang for the buck" i'm open to all suggestions, this is mainly going to be a street/strip car, i ALREADY HAVE THE PARTS LISTED so thats not going to change !
1985 trans am 3200lb car give or take a few lbs
3.42 gear ratio
(dont have much of an option for gears, 9 blot gta rear end)
turbo 350
3000 stall
26x10.5x15 m/t et streets
i have a 350 .30 over 4 bolt main
.125 dome trw pistons
stock crank and rods
750 holley mechanical secondary
professional products hurricane intake
11.1 compression
procomp aluminum heads 2.02/1.60 link to the heads specs,
http://www.procompelectronics.com/index.php?target=products&product_id=37060
and 1.5 roller rockers
i would like to go hydraulic roller or solid roller but i'm on a budget so let me know what you think!
thanks Brian
Old Nov 12, 2008 | 12:26 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: i need a cam for a .30 over 350
Is that CR calculated, or guessed based on what the piston mfg says? ie, did you measure the deck height yourself, and do the math?
Is it balanced?
Have you replaced the rod bolts and main bolts?
What year is the block? ie, roller block?
Old Nov 12, 2008 | 12:38 PM
i based it off of what the trw spec say, 125 dome with 64 cc heads will be 10.7.1, i do not plan on having it zero decked, unless it is unlevel, it will be balanced, yes the rod and main bolts will be replaced, it is an 89 block as far as i know, it was rebuilt before i got it and it had flat tappet lifters in it but the block is driller for the "lifter spider" now this is not my first engine build by all means, but this is my first engine in a 3rd gen, i just got done building a 505 bbc for my 72 protouring chevelle!
www.fquick.com/dioismyhero for pics
camaro71633
Sep 1, 2015 10:24 AM
michealleger
Aug 26, 2015 03:29 PM
Eric-86sc
Aug 24, 2015 09:01 PM
neekolzun
Aug 24, 2015 04:59 PM
theshackle
Aug 22, 2015 06:52 PM
