Computer controlled?
Old Nov 13, 2008 | 06:02 PM
lee33lyn's Avatar
Car: 84 Z28
Transmission: 5speed
Axle/Gears: 3:23 posi disc brakes
I have a 84 Z 5speed 305 is it comp controlled car?
thanks
Old Nov 13, 2008 | 06:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Unless it was originally delivered in Canada, yes, it is computer controlled.
Old Nov 13, 2008 | 06:35 PM
lee33lyn's Avatar
Car: 84 Z28
Re: Computer controlled?
what all does the comp do in a man trans car ? Can I take it out ?
Old Nov 13, 2008 | 07:16 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
No. It controls primary mixture and ignition timing.
Old Nov 14, 2008 | 02:06 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
Hated that comp. controlled carby. Had mine taken out and replaced it with a standard Rochester and new dizzy. Works much better.
Old Nov 14, 2008 | 04:12 PM
five7kid's Avatar
The computer controlled q-jet is the best possible street performance carb out there. Anything you could put on in its place would be a downgrade. The two I've had worked flawlessly when adjusted per factory specs.
However, with a T5, a double pumper carb can be justified. But, it will be more of a hassle to set up, to say nothing of the expense.
Old Nov 14, 2008 | 04:30 PM
lee33lyn's Avatar
Car: 84 Z28
I bought a wrecked 305 215 hp car. It has a TPI in it and I want to put the block and heads in my 84 and use the stock intake and carb from the 84 LG4.Do I need to program the comp? How about the carb? Do I need to put bigger jets in the carb? I think I'll stick with the 305 until I blow it up. By then I should know all the rules.
Old Nov 14, 2008 | 05:27 PM
naf's Avatar
naf
No need to reprogram the ecm and you should only have to change out the secondary rods and hangers. You will likely need to adjust the carb to the new motor. A dwell meter and a volt meter (for the TPS) are all the 'extras' you'll need.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
camaro1185
Oct 26, 2015 06:51 AM
Doobie52
Sep 11, 2015 06:19 PM
dbrochard
Sep 7, 2015 09:41 AM
Jlanz55
Sep 6, 2015 02:35 PM
