Can I bypass the Oil pressure switch?
Old Nov 13, 2008 | 06:42 PM
blackdemon89ta's Avatar
If i wanna by pass the switch can i just connect the wires and run the third one to a gauge?
I'm swapping from tbi to carb. so i'm trying to get rid of all the relays and computer. to clean out the bay but with out the oil pressure switch the car dies.
Old Nov 13, 2008 | 06:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Can I bypass the Oil pressure switch?
If you do that, your fuel pump will run continuously.
Old Nov 13, 2008 | 07:06 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
just leave it in place and wire the fuel pump relay to engauge with the ignition in the run position to power the pump. It will function as a backup for the fuel pump relay should it fail like it does in a factory setup. Depending on what year you car is it may also send the reading to your oil pressure gauge. Also unless your fuel pump relay is bad the engine will not die without the oil pressure switch, it's not a saftey switch, it's a backup for the fuel pump relay.
Old Nov 13, 2008 | 07:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
When switching to a carb the fuel pump relay becomes useless and you'll need to rely on the oil pressure switch.
Old Nov 14, 2008 | 01:53 PM
ok thanks for clearing that up.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
TA8487
Aug 16, 2015 12:21 PM
