1.6 roller tips ???
Old Nov 16, 2008 | 07:52 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
1.6 roller tips ???
o.k. i have searched . could not find an answer . going to install comp. cams 1.6 roller tip rockers . have heard that i may have pushrod clearence problems . how do i determine if i will have this problem ? the eng. is an un-molested LO3 ( not for long ) . will be doing headers , valve seals/springs , MSD , motor mounts at the same time . anyway i have heard that the pushrod passages can be drilled out to 3/8" for clearence with out removing heads . if so how ?? sounds like it might be possible but how ?? i would be concerned with drilling chips falling into engine . has anyone actually done this with out removing heads ? i have no problems with my other plans except this . any comments/results on this subject would be great . car is a regular driver , not a racer . please respond with actual experience .
Old Nov 16, 2008 | 08:28 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: 1.6 roller tips ???
go on www.jegs.com and put in part#249-4710 its the crane cams louis tool $34.99 designed for what youre doing to your heads,jimmy
Old Nov 16, 2008 | 08:50 PM
UNCLE TOM's Avatar
thanks , i may get one . results/how to do with out getting metal inside eng. is what i am concerned about without removing heads . thanks again .
Old Nov 16, 2008 | 09:34 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I have these same rockers (Comp roller tips) and you will NOT have any problems with them. I have been running them for 3 years with absolutely no issue. I recommend them. If the car is a regular driver and you just want alittle more kick without a big tuning headache I recommend a Vortec/ baby- LT1 cam. It's not a big increase but with the 1.6 rockers it would give you this.
194/199 - .446/459 lift. 111 LSA
I would also recommend a S10 convertor for a bit more stall.
jrdturbo
Mar 31, 2016 02:58 PM
Thaney9
Oct 15, 2015 06:37 AM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Night rider327
Sep 25, 2015 04:47 AM
