Clearance Issues with 168 Tooth Flywheel
Old Nov 17, 2008 | 10:23 AM
hectre13's Avatar
Car: 1984 15th Anv. T/A
Engine: HO 5.0
Transmission: TH700r4
Axle/Gears: not sure yet!
Ok, So the engine in my car right now is an L98 engine, I seized it up, so im pulling the engine out and putting in a built engine from a suburban, heres my problem. the flywheel on the new engine is a truck flywheel with 168 teeth. I'm going to be running some hedman shorty headers, so I know with the truck starter, there is going to be an issue.
I was thinking, I could either take the flywheel off my L98 setup, but if I do that, I'll hafta take it in and get it balanced with my rotating assembly so that I can use the starter from my L98 setup.. which getting all that balanced is getting up there in price..
or
I could buy a ministarter and fix my clearance issues (im assuming), from what I hear if I buy a mini starter, I shouldnt have any problems, is this correct?
I'll be running hedman 68470's, I was hoping not to spend a ton of money on this, so I was wondering would this starter work? and clear all my clearance issues?
http://store.summitracing.com/partde...820323&FROM=MG
it's a summit brand one, but it looks pretty slim and small.. what do you guys think?
Old Nov 17, 2008 | 11:00 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: Clearance Issues with 168 Tooth Flywheel
That's the one I've been running for a few years. I had to do some grinding on the block and/or starter to get it to tuck up as tight as I wanted.
Old Nov 17, 2008 | 11:03 AM
hectre13's Avatar
Engine: HO 5.0
so.. in your personal experience, with what i said about my setup, this starter should solve my problem?
Old Nov 17, 2008 | 11:10 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
I'm also running the hedman shorties with that on my car, so yes.
Old Nov 17, 2008 | 11:28 AM
hectre13's Avatar
Engine: HO 5.0
thanks a lot.. i'll go ahead and order them then..
Old Nov 17, 2008 | 12:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by hectre13
I could ... take the flywheel off my L98 setup, but if I do that, I'll hafta take it in and get it balanced with my rotating assembly so that I can use the starter from my L98 setup.
Why do you say that? Was your flywheel modified to balance the L98 rotating assembly?
If not, as long as they are both the same rear main seal type, it should transfer directly from one engine to the other.
By the way, if this is for an automatic transmission car, it's normally referred to as a "flexplate" to distinguish it from the heavier piece required with a clutch.
mhatfield 14
Oct 24, 2015 07:48 AM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
Trickskier
Aug 29, 2015 01:12 PM
sreZ28
Aug 14, 2015 07:48 PM
milk
Aug 10, 2015 06:26 PM
