Vibrations
Old Nov 20, 2008 | 11:55 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Vibrations
I notice my engine vibrates right around 1700 rpm, anything less or more is perfectly smooth. It does it whether the car is siting still or going down the road. It doesn't jump or anything when I put it in gear, so I don't think it's the motor mounts. Could this be the harmonic balancer?
('87 350 TPI)
Old Nov 21, 2008 | 08:39 AM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
Re: Vibrations
It's possible. Could also be motor mounts. Could be the A/F mixture (I wouldn't think so since it happens both still and driving). Could be really anything that is part of the rotating assembly of the engine from the harmonic balancer to the torque converter.
The main thing that kills harmonic balancers is when they are installed using a hammer. There is a special tool for installing/removing them.
Old Nov 21, 2008 | 11:11 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Re: Vibrations
Hmm, well my torque converter doesn't lock up. I'm going to replace the TCC solenoid soon, so I'll see if it even works at all after that.
Old Nov 21, 2008 | 12:24 PM
OldCelica's Avatar
Re: Vibrations
I would also assume that if the veins in the converter decided to move to another part in the converter that would throw off the balance. Kinda like if someone moved the wheel weights around randomly.
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
