1992 Camaro - starting issues
Old Nov 23, 2008 | 09:05 PM
BeeSting's Avatar
I bought a 1992 Camaro RS (305 TBI) from some guy who needed the cash as much as I needed something to drive. With what I paid, I thought he was the chump until the issues started arising...
I cant get the car to start. Upon hearing that he had rebuilt the starter himself, I replaced it altogether. Still nothing. When I turn the key I dont even get a click or any sound from the starter/solenoid at all. I do have power, the positive cable is brand new, too.
Whats next? For a while I was able to wiggle the positive cable a bit to get it to start - but I think the solenoid was bad because the plastic cap was moving around. Now - nothing.
I thought I was done with cars for a while after I picked up a bike this summer - but it looks like Im back in the thick of it. Any good advice would be MUCH appreciated.
Old Nov 23, 2008 | 09:25 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: 1992 Camaro - starting issues
Is the "Security" light on the dash panel lit?
If you jump the terminals on the starter solenoid, does it start?
Old Nov 23, 2008 | 09:46 PM
BeeSting's Avatar
No the security light is not on.
I need to try jumping across the terminals. I've bought two bum car jacks this week so I have to get another to check that out.
Old Nov 24, 2008 | 04:29 PM
BeeSting's Avatar
Ok, so my workday is over and I go outside to try jumping the solenoid. I figure "why not try the key, just to try it", and it started up.
So... I guess that eliminates a starter/solenoid/cables to and from issue...?
So what now? Could there be something in the ignition wiring thats giving me this headache? and if so, what can I do to bypass it and prevent further issue until I can really get down and rewire this thing?
Old Nov 24, 2008 | 09:16 PM
1992CamaroRS305's Avatar
im having the same problem but the security light is on when i try to start the car. My battery and cables are good, so iunno
Old Nov 24, 2008 | 09:24 PM
BeeSting's Avatar
You need to check out some of the other threads about security bypass. There's lots of info on that
Old Nov 26, 2008 | 11:37 AM
DJ_SirG's Avatar
Car: 1986 Trans AM tpi
Transmission: A4
Axle/Gears: 277 Posi
I have had that prob twice. I opened my hood and looked around, didn't see anything, closed the hood and it started. I think it has something to do with the security but I'm not sure. Mine is unplugged because I cant find the controllers for it.
Anyone know where you can get replacement controllers?
Old Nov 28, 2008 | 09:23 AM
amaraz's Avatar
Car: 92 camaro 25th anniversary
Engine: 3.1
Transmission: auto
Do you hear the fuel pump start,if not probably the VATS pick ups in ignition bad. Can be bypassed with resistors, did mine with parts from Radio Shack for about 2.00 bucks.
Old Nov 29, 2008 | 08:28 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I just fixed this problem (or simular one) in my 92. It was the ignition switch that had gone bad. Car stopped on me at the car wash...right after everyone there complimented me on how sharp my car was...lol...very embarassing....anyway the switch is down the steering column...when I turned my key everything would light up (security light stayed on) would not turn....the rod that slides over the ignition switch was not moving far enough to start the car... I bypassed the VATS at the same time. My plan is to install an aftermarket alarm and remote start around stimulus/income tax time.
92camaroJoe
Jul 29, 2023 07:57 PM
Vintageracer
Jan 10, 2020 05:33 PM
92camaroJoe
Aug 13, 2015 06:07 AM
