Where does this hose go????
Old Nov 24, 2008 | 02:08 PM
91_z28_guy's Avatar
Car: 91 CAMARO Z28
Engine: 5.8L TPI 355 L98
These are a few hoses on the right side of my motor.(350 tpi) i dont know where these vacuum hoses connect to. Any help is appreciated.
Attached Thumbnails Where does this hose go????-dscn2895.jpg   Where does this hose go????-dscn2894.jpg
Old Nov 24, 2008 | 02:32 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: Where does this hose go????
i think its to your heater control valve if you need more help ask
Old Nov 24, 2008 | 02:48 PM
91_z28_guy's Avatar
Car: 91 CAMARO Z28
well i know that the two hoses are pretty close together. One has two hoses on it 1 which goes to the fpr and the other i dont have a clue. Now there is a rubber hose comeing from the canister that runs down the drivers side behind the motor but i dont know what that hooks up to.
Old Nov 24, 2008 | 06:05 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Your first pic, the plastic line laying on the runner will snake its way under the plenum to the throttle body. There is a vacuum port under the throttle body on the driver side it connects to. The other plastic line in your first pic that I see which is laying up against the coil will connect to the vacuum port under the map sensor. It is for the heater controls in the car. Should be a check valve/splitter that will connect with it. Cant see what your pointing at in the second pic. Hope this helps.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
2012sergen11
Oct 13, 2015 07:38 PM
Stryker412
Sep 20, 2015 06:59 PM
st.evel07
Sep 19, 2015 09:24 PM
