UH-oh...Stripped threads. Will this seal?
Old Nov 26, 2008 | 10:43 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
One intake bolt hole in my aluminum heads got cross threaded so I ran a tap through it and almost got it to work.
While installing the manifold today this hole completely stripped and now I am wondering if this will still seal.
It is the second bolt hole from the front of the motor on the passenger side (#11 to torque down). I'd say there is less than 10 ft. lbs.. All the others are just fine.
Is this guaranteed to leak? 50/50? Or shouldn't be a problem?
Old Nov 26, 2008 | 11:32 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: UH-oh...Stripped threads. Will this seal?
Why not just heli-coil it?
Old Nov 27, 2008 | 01:02 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Just not wanting to pull the manifold and also risk metal shavings.
I could hope for the best and if I can detect a leak when I fire it up heli-coil it then.
Old Nov 27, 2008 | 10:09 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Old Nov 27, 2008 | 11:03 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
You mean after the intake warps? :-) Best to helicoil it.
Old Nov 28, 2008 | 09:22 AM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
I also like to use anti-seize with aluminum. Don't have to drench it, just a slight film will do.
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
