To Rich 02 sensor
Old Dec 2, 2008 | 12:02 PM
robster66's Avatar
Car: 1992 Chevrolet Camaro RS
Engine: 305 T.B.I.
Axle/Gears: 2.73 Open Diff
To Rich 02 sensor
My car will not start because it is to rich which I think is the 02 sensor. How do I make it run leaner for the time being so I can warm up my car to replace the 02 sensor?
Old Dec 2, 2008 | 12:44 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: To Rich 02 sensor
The O2 sensor isn't used at startup. It doesn't switch to closed loop until it's hot. If you're really rich you may have a leaking injector.
Old Dec 2, 2008 | 12:59 PM
robster66's Avatar
Engine: 305 T.B.I.
I got it to run, replaced coolant temperature sensor, and oxygen sensor. I am not getting check engine light, I think it runs a little bit leaner. The next thing to do is timing I believe.
db057
Jan 10, 2020 08:55 PM
tuningnewb
Sep 23, 2015 07:06 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
89fast5oh
Sep 8, 2015 09:55 AM
Jk_Under
Sep 8, 2015 08:13 AM
