Wire Keeps Burning
Old Dec 2, 2008 | 07:54 PM
86firebirdta's Avatar
Car: 1983, 1986, 2001 Trans Am
Engine: 305 cfi, 350 carb, LS1
Transmission: 700,Edge 2800 th350,Edge 3400 4L60E
Axle/Gears: 9 Bolt 3.27 Borg-Warner, built 3.73
Wire Keeps Burning
I have an 86 trans am 5.0 FI and jus recently the wire that feeds into the back of my altanator has been burning off and there is a lot of corrosion around the connection i have had my check engine light come on once before reading out high voltage at the battery but has never been on after that one incident.... Any ideas wat can be causing this????
Old Dec 2, 2008 | 08:19 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
Re: Wire Keeps Burning
Overcharging would indicate a bad voltage regulator. Corrosion is going to cause unwanted resistance on that wire which may be the problem.
Old Jan 11, 2009 | 09:50 PM
creese187's Avatar
i would make sure you have a good ground and power clamps on the battery and alternator, you can check the output voltage of the alternator, at the battery while its running, it should be about 13.5-14.5, if its more, you probably have a defective voltage reg. within the alt.
eightsixseven
Dec 16, 2024 01:50 PM
GTAman
Mar 15, 2019 11:40 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Bryan F
Aug 18, 2015 02:28 PM
Exxon Limited
Aug 9, 2015 08:13 PM
