Howto use timing light?
Old Dec 4, 2008 | 04:06 PM
robster66's Avatar
Car: 1992 Chevrolet Camaro RS
Engine: 305 T.B.I.
Axle/Gears: 2.73 Open Diff
From what I have read in the manual and such I have to disconnect this wire before doing it. Also on my VECI label or whatever it says 0 degrees BTDC. http://www.amazon.com/gp/product/B00068OJZS that is the timing light I ordered and it should arrive very soon. From my understanding you put the one clip on #1 spark plug wire and it flashes for everytime number 1 fires. Where do I aim it and which way to turn the distributor?
Old Dec 4, 2008 | 04:25 PM
robster66's Avatar
Engine: 305 T.B.I.
Re: Howto use timing light?
I am guessing since it wants it 0 degress BTDC I locate the 0 on the timing marker and the line on the harmonic balancer has to line up with that everytime it flashes? How can I clean the timing marker to see the 0 without taking everything apart?
Old Dec 5, 2008 | 09:01 AM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
You are correct. Usually the deeper V on the timing tab is 0.
Old Dec 5, 2008 | 11:13 AM
robster66's Avatar
Engine: 305 T.B.I.
Thank you very much that helps a lot.. The line on the harmonic balancer is 0 degrees also? So they both line up or are suppose to
Old Dec 5, 2008 | 11:37 AM
OldCelica's Avatar
The line on the balancer corresponds to the position of the crank. When that mark lines up with the 0 degree mark on the timing marker then the number 1 piston is at top dead center.
Old Dec 5, 2008 | 11:49 AM
robster66's Avatar
Engine: 305 T.B.I.
Easy enough thank you very much!
Old Dec 5, 2008 | 02:34 PM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
You may want to use a little bit of white out on your timing mark and balancer. It will help you see them easier with the timing light.
Andrew6.688
Dec 13, 2015 10:59 AM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Omega
Aug 10, 2015 12:46 PM
Thirim
Aug 9, 2015 06:19 PM
