Factory Oil Cooler Question
Old Dec 6, 2008 | 10:13 AM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
Can I leave the cooler between the filter and block in place and just cap off the two outlets (mine has about 3" of hose between the hardline and the cooler)? Obviously, I'll reroute on the other end, as well. This way, if a future owner wants to put the car back to stock (if there ever is one), it's one less thing to do.
Kevin
Old Dec 6, 2008 | 11:02 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Factory Oil Cooler Question
You can. Why not just leave it working, though?
Old Dec 6, 2008 | 11:53 AM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
I can't find the short molded hoses and using straight hose causes a constant leak. The hardlines are a pain to work around under the car and provide minimal (if any) benefit. If I experience unbearable driving conditions from the lack of coolant running around the filter housing, I can always intensify my effort to find the hose. Nobody is ever going to pay me what I have invested in the car anyway, so I in terms of value, I can't believe I'm doing anything that bad
Old Dec 6, 2008 | 01:59 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
I used 3/4" straight heater hose and it doesn't leak. You can just leave the hoses off it or remove it (you'll have to replace the two mounting bolts with shorter ones though).
Old Dec 6, 2008 | 03:10 PM
gtaproject's Avatar
Car: 88 GTA
Engine: 305 LB9
Thanks - I just capped them off. Should I ever find the correct hose, I'll consider re-installing. Straight hose didn't work for me, and I've opened up a little more room when working under the car (which I do much more than driving it).
Old Dec 6, 2008 | 06:00 PM
jv9999's Avatar
Engine: 5.7L/350
If you loosen the bolt in the middle you can spin it. It makes installing new hoses a lot easier. Also a good time to replace the rubber seal.
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
