Injector size? Fuel pump?
Old Dec 18, 2008 | 09:08 PM
1970 Buick's Avatar
Car: 1989 GTA
I am installing ported plenum and base and siamese runners and 58mm TB. I am going to be putting more air in so I need to increase fuel too ( I assume?) What size injectors should I install and do I need to get a bigger fual pump too? Any advice is greatly appreciated!
Old Dec 18, 2008 | 09:14 PM
92whiteta's Avatar
Car: 86 WS6 Firebird
Engine: 355
Axle/Gears: 2.73 open
Re: Injector size? Fuel pump?
what else is done to the motor if that is all of the mods i would just increase fuel pressure and not worry about injectors. also what engine size are you working with?
Old Dec 18, 2008 | 09:29 PM
1970 Buick's Avatar
Car: 1989 GTA
350 engine. Should I invest in a fuel pressure regulator. Nothing else done to engine except headers.
Old Dec 20, 2008 | 08:47 AM
92whiteta's Avatar
Engine: 355
yes i would just add a fuel pressure regulator and not worry about the injectors the increased air entering the motor will not be enough to need new injectors
Old Dec 20, 2008 | 08:53 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
if you are in california a fuel pressure regulator is illegal in street machines. check your state laws, because its hard to hide the darn thing, it sits right out there.
jklein337
Sep 19, 2018 06:23 PM
gta90
Sep 15, 2015 04:00 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
