Door locks
Old Dec 19, 2008 | 12:15 PM
Robb Knight's Avatar
Car: 1989 Firebird Formula 350 TPI
Engine: 5.7 350 TPI
Door locks
Im not sure if this would be the right place to ask this question. I apologize in advance if this is not the right area. If I indeed placed this in the wrong area, if someone knows a better suited area I would be more than hsappy to put it there. Thanks in advance.
For whatever reason I have seen many 3rd gens over the years, some of my own, and this seems to be a fairly common issue. The keyhole in the door locks will stop working. Usually in the cars with the power locks. Dont recall if I saw it on a non "power" lock car. Its usually the driverside door. As is the case with both my birds. One being a 87 TA and 89 Formula. In both I can get the key to either go all the way or most of the way but it wont turn in either direction. Now Im fairly certain theres nothing wrong with the actual locks, just the keywhole mechanism I guess. Because they can both be locked and unlocked from the inside and the power door buttons work also. So both manual and with the power buttons the car can be locked and un-locked from the inside. Normally the passenger works fine, as was the case with both cars until recently. On the 89 bird the passenger side recently started screwing up. I was wondering if anyone knew what the problem might be or if they have experienced similar issues.
Old Dec 19, 2008 | 12:26 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
YOU HAVE 2 CYLINDERS? I HAVE 8!
No big deal.
Lock cylinders wear out due to a great deal of use.
Also:
Lock cylinders get sticky due to a lack of use.
“ya kant win”
I have actually removed my cylinders and sleeked the body so now they operate VIA key fob remote only.
If your cylinders are giving you problems replace them.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Old Dec 19, 2008 | 12:41 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Door locks
Originally Posted by Robb Knight
II was wondering if anyone knew what the problem might be or if they have experienced similar issues.
My pass side lock (power) acted as you describe. The cylinder was frozen from lack of use or lubrication. After replacement, all was well. Lock-Ease or a similar product will eliminate the problem in new locks.
JamesC
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
my86bird
Oct 23, 2015 12:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
SG91camaro
Sep 5, 2015 10:27 PM
