Total Seal Rings?
Old Dec 25, 2008 | 09:31 AM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
Transmission: 5 Speed Manual
Axle/Gears: Probably the stock 3.42
Total Seal Rings?
are they worth the power they claim? i have done a search and seen that they work fine, but do they add the 15-20 hp they claim as well as the 10-12 inches of vacuum? and with this extra vacuum could you use a bigger cam and still use power brakes without a canister thingy?
oh the ones im talking about are the MAXseal gapless, with the gapless top ring and conventional second ring...
thanks
Old Dec 25, 2008 | 07:59 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: Total Seal Rings?
thanks
I've used them on 2 rebuilds, they work great but I can't verify their test results...I do know I used the "Quick Seat" powder instead of oil when installing the pistons as per their directions, and have little if any blow-by. I've used the TSS gapless rings as well as the blower set I have in it now.
Old Dec 25, 2008 | 10:29 PM
oxrabidus's Avatar
Car: 1989 Camaro RS
Engine: 2.8l v6
yeah i have heard nothing but good things about them, but i have yet to hear if they are really worth any power or added vacuum... which is why im really interested in them...
Old Dec 25, 2008 | 11:10 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I use a Total Seal top rings in my engine. Leakdown remains low.
I wouldn't go by any HP or vacuum claims unless done by an unbiased third party. Each engine is different.
Old Dec 26, 2008 | 10:16 AM
grumpyvette's Avatar
IVE used them on several engines, as far as IM concerned they are NOT worth the extra cost, they work just fine but IVE seen little or no improvement over standard rings that were installed correctly.
think about it, theres about 2-3 thousands at the most between a piston and a bore once the engines up to operating temp,the ring end gap is about 5-8 thousands at most once the engines up to operating temps, a pistons doing a compression stroke 20-60 times a SECOND when the engines running, how much compression can you loose thru the end gaps of two compression rings with thier gaps spaced on differant sections of the piston anyway.
Old Dec 26, 2008 | 02:31 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
I agree with grumpy. I've got a set of total seal's in a rat motor and other than soaking my wallet more we can't see any difference at all. I'd say spend that extra money you save by not buying total seal's and have your block honed with a torque plate to get the bores as round as possible.
Old Dec 26, 2008 | 04:11 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
I`ve used them and have them in my current combo, I like the childs and albert Z gaps but Im running the max seal totals right now, leak down is near the same after 2 yes and 150+ runs and thats with 125-150 worth of nitrous on most runs, no blow by or pressure in the crankcase. For a strictly N/A application I`d use them without a thought , for heavy nitrous 250+ it`s just not recomended. I`ll be switching to hell fires this next tear down.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
BOOT77
Sep 16, 2015 08:37 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
DARKmj16
Sep 9, 2015 04:07 PM
BOOT77
Sep 5, 2015 03:55 PM
