tpi 350 engine block component weights
Car: 1989 Chevy Corvette
Engine: 383 SuperRam 10.7 AFR 195 220/229
Transmission: Fancy Smansy 87 Corvette 700r4
Axle/Gears: 3.33
how much does a block with main caps weigh?
stock crank?
rods and pistions?
all together can one person lift it into a trunk of a car?
or does it have to be taken apart?
is a stock crank, rods and pistons worth trying to sell?
thanks
stock crank?
rods and pistions?
thanks
Car: '91 Camaro RS
Engine: 355 TPI, Comp 268xfi, bowtie heads
Re: tpi 350 engine block component weights
one person can carry a bare block, with rods pistons and crank it's going to be upwards of 250 pounds or so, so it's kind of iffy, depends on how strong you are
you could probably sell the crank if its in good shape, rods maybe, pistons are probably worthless unless they're oversize
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
