Firing Order/Distributor question
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
I noticed today that the wires on my L98 are hooked up differently than the wires on my L05. On the L98 the wire to cylinder #1 is hooked up up to the distributor cap on the peg that is physically closest to the number one cylinder, on the "bottom right" of the distributor, if you will (about 5 o'clock). On the L05 the #1 plug wire is hooked up to the 1 O'clock peg on the dist, the top right if you will. Other than this the firing order seems to be correct on both. Is this all okay? Did somebody put the distributor in wrong in the L05 and connect the wires to make up for it?
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: Firing Order/Distributor question
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
#1 can be anywhere on the cap depending how the distributor was dropped in. Putting #1 in the 5 o'clock position makes putting the plug wires on easier.
Apparently someone didn't know how to install the distributor on the LO5. Firing order is clockwise 18436572. 5 and 7 are always easy to mix up. I would have liked to be around when they were trying to fire up the engine. #1 plug wire was probably still at the 5 o'clock position and they had to rotate the distributor that far to get it to fire. Instead of pulling and turning the distributor, they just moved the wires.
92camaroJoe
Aug 13, 2015 06:07 AM
