Weird Idle issues, need a little advice 1991 z28
Old Jan 1, 2009 | 01:52 PM
scottjake's Avatar
Car: 1992 Camaro Z28 Convertible
Engine: 5.7TPI transplant
Transmission: a4
Axle/Gears: 3.08
Info: 1991 Z28, stock mechanically.
The issue is that on initial cold startup, the idle speed is 5-600 rpm, after about 15-30 seconds the idle ramps up to 1000-1100 rpms and will idle at that speed all the time. It does seem to search for an idle speed a little, but not much maybe a 50rpm oscillation.
We have checked for vacuum leaks, none. The car runs pretty good otherwise. It does definitely run quite rich at idle, but in driving around does get fairly good gas mileage.
I'm not sure if I have a coolant temp sensor problem, base idle speed problems. Im just at a loss that initially the car will idle so low then ramp up to the higher idle speed. I have cleaned the outside of the IAC motor, but I cannot see it move at all.
Anyway, just looking for a little help.
Scott
Old Jan 4, 2009 | 11:39 AM
87whiteiroc's Avatar
Car: 87 Camaro
Engine: 5.7 350 TPI
Re: Weird Idle issues, need a little advice 1991 z28
try checking the o2 sensor mine had the same problem. stock headers use the autozone or napa sensor, on aftermarket headers get a heated sensor.
specialized
Jun 18, 2022 09:26 AM
jhawkeye
May 25, 2022 06:33 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
jbd1969
Aug 17, 2015 07:06 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
