cylinder head question
Old Jan 1, 2009 | 03:18 PM
72vega's Avatar
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
i did a search on here so it hasnt been brought up before that i could see.. does anyone know if anyone makes a vortec style LT1 head? i was wondering if it would be possible to put the ramjet 350 intake on an LT1...
Old Jan 1, 2009 | 05:31 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: cylinder head question
The Vortec head design was based on the LT1 cylinder head. The chamber design is very similar, as is the intake port design, though the LT1 does not have the raised ports that the Vortec heads have. The LT1 head uses the standard SBC intake port layout, but with an altered intake bolt pattern.
Why do you want to use a RJ350 manifold on an LT1? I'd bet an LT1 intake flows the same or better than the RJ intake, and it would cost you alot less to obtain
Old Jan 1, 2009 | 05:37 PM
72vega's Avatar
just some daydreaming...
fasteddi
Sep 2, 2015 10:29 AM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
