how to get the intake off?
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
I was at the junkyard today and i found a camaro exactly like my own, dunno about the year but it was the same L03 TBI engine, I've been thinking about heads or intake or something like that so I was just going to take off the intake just to make sure it i was perfectly capable of doing so on my own car, so after i removed everything, the bolts on the intake, the distributor, tbi unit, throttle linkage, everything but the egr because it didn't seem necessary. so anyway I tried to lift it off and it wouldn't budge, i tried picking around it with a flathead and that didn't do anythign either, so i resulted to pulling from the bores and the thermostat housing, this did not work either so i gave up and went home, i'm not sure what i should do in the case, there isn't much clearance anywhere to get any good leverage with anything flat to stick between the intake and block of the engine to pry it up, any suggestions?
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
Re: how to get the intake off?
try a prybar or a wrecking bar with some gentle taps from a hammer.
Transmission: 4L80E/4L80E
Have you heard the saying, "If it seems too good to be true, it probably is?"
Similarly, if it seems like there's still a bolt holding it on, there probably is.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Did you take one or both valve covers off? If it feels loose, but won't lift off, its probably hanging up on the valve cover flanges.
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
