which head gasket set to buy?
Old Jan 2, 2009 | 11:23 PM
fychelio's Avatar
Car: 1983 pontiac Trans am ws6
Axle/Gears: ????
i found these two part numbers under different vehicles at autozone.com this part number was found under a 1979 chevy camaro 5.7L 4bbl part #HS7733PT-2 . And this part number was found under a 1983 Pontiac trans am 5.0L 4bbl ohv part #HS7733PT-2, the gasket set for the 79 camaro looks better and i think it comes with the severe duty head gasket and the one for the trans am doesnt look like it in the picture it seems to be a regular felpro gasket not the severe duty..... my setup is a 350 4bbl (700r4 tranny if anyones cares) all stock computer ran not manual. which set should i get. and should i get new head bolts? or just clean old ones. and since im this deep into the engine, any other ideas for adding some horse power before i close her up?
Old Jan 3, 2009 | 02:40 AM
fychelio's Avatar
Axle/Gears: ????
Re: which head gasket set to buy?
Really?? wow thanks i was thinking the same thing..
i didnt even think about that your so much help!!!
as the sarcasm continues, i took the liberty of posting the same question on a toyota forum and actually got a mildly decent response...intresting that someone their actually knew
Old Jan 3, 2009 | 03:50 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Funny how people ask a question at midnight, and expect a throng of answers within 3 hours.
HS7733PT2 is going to be the same kit, doesn't matter what vehicle it's for. A part number is a part number. They're the same kit.
Stock head bolts can be reused. Assuming its just do-over rebuild, they will be fine.
Old Jan 3, 2009 | 05:17 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
If you use the old head bolts, make sure you clean the threads before you re-use them.
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
NWAsonoma
Aug 18, 2015 05:45 PM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
