350 engine help
Old Jan 3, 2009 | 02:34 PM
howy03's Avatar
Car: 1985 Pontiac Trans Am
350 engine help
I picked up a 350 engine for free today was told it was a performance gm crate engine the block #s are 1024388c 5.7 lg SGI it has vortec heads.The engine sucked a valve and damaged one piston.I was also given an older set of heads that were off a running motor #333882.The engine was from a friend who got the Damaged crate engine that was replaced under warranty,It ran for one day.The lower end and cam and lifters look new.My question is can anyone tell me if I am able to replace the piston and have the cylinder honed or sleeved would these heads work on this motor.Any info on the #,s or suggestions were to start with this engine would be great.This would be my first engine build and appreciate any help.Sorry for the long read! Howard
Old Jan 3, 2009 | 02:40 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 350 engine help
The whole thing should be taken apart and checked for damage.
The 882 heads are garbage.
Old Jan 3, 2009 | 03:20 PM
howy03's Avatar
Re: 350 engine help
what should it cost roughly to have the block and crank checked out
Old Jan 3, 2009 | 03:21 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 350 engine help
Prices vary. Call your local machine shops and ask.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
