fan wont turn off?
Old Jan 6, 2009 | 02:16 PM
91rs5.7tpi's Avatar
Car: 1991 rs camaro
Engine: 5.0
Transmission: t-5
fan wont turn off?
i took off my air system and put headers on now my fan wont turn off it stays on constantly dont have service light on or nothing . car acts fine but my fan stays on. any solutions or is that normal after taking off the air system
Old Jan 6, 2009 | 05:17 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: fan wont turn off?
i am pretty sure when you removed manifolds you disconnected fan sw. wire . on pass. side cylinder head between the 2 rear plugs is a sensor , it is the fan sw. . it should have a single wire going to it . when coolant reaches a fixed temp. it grounds internally turning fan on . if wire is not connected it is grounded some where keeping fans on . if connected you may have a bad sensor/switch . good luck .
Old Jan 6, 2009 | 06:37 PM
91rs5.7tpi's Avatar
Car: 1991 rs camaro
Engine: 5.0
Transmission: t-5
ya i had to replace that maybe the wires arnt connected good enough thanks for the help
Old Jan 7, 2009 | 01:30 AM
Aarons92Maro's Avatar
Car: 1992 Camaro RS & 1994 Mazda 626
Engine: 305 TBI V8 / 2.0 4-cyl.
Transmission: 700R4 / I have no idea
Axle/Gears: Stock 2.73 / I don't know
I have a related question. My fan seems to stay on all the time too. As soon as I turn the ignition one notch over, the fan starts running. Same thing?
Old Jan 7, 2009 | 09:59 AM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
There is a relay on the drivers side firewall that is oval shaped. It is your fan controll relay. I would check that. Mine went out and when i would shut off the car the fan would stay running.
RazorN8
Jan 7, 2022 11:44 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
bryanwood74
Sep 24, 2015 09:50 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
