TPS Testing
Old 01-07-2009, 07:48 AM
andyz77vette's Avatar
TPS Testing
Does anyone know how to ohm out a TPS (Throttle Position Sensor) off an 87 TPI Motor. It has 3 prongs. Which ones do you ohm out?
Old 01-07-2009, 09:44 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: TPS Testing
1) Disconnect harness connector from TPS
2) Measure between Pins A - C it should measure about 5 kOhm (there are variations on this value, but generally it is about 5K). This should be constant regardless of throttle position.
3) Measure between Pin A and B or between B and C - resistance value should range from minimum of 1 kOhm to maximum of 6 kOhm. Value change must be smooth without any dropouts and jumps!
//RF
Old 01-12-2009, 01:34 PM
creese187's Avatar
Re: TPS Testing
check the bottom two, 0.45 volts closed opening progressivley to 5.0volts, it should be a nice smooth transition, you dont need to ohm it out if this is ok, obvioulsy do this with the key on, engine off
BumpaD82
02-26-2016 02:57 PM
L98GTA87
10-19-2015 10:43 PM
RedLeader289
09-23-2015 06:50 AM
reactor60
09-22-2015 01:44 PM
Quick Reply: TPS Testing
