L98 Aluminum head thread repair
Old Jan 12, 2009 | 01:56 PM
oscarfromla's Avatar
Car: 88 Iroc-Z
Engine: 355 AFR-195 FIRST Fuel Inj.
Axle/Gears: ??
I'm going to be pulling my L98 aluminum heads to replace some cheap leaking headers as well as to repair some stripped threads for both the intake manifold bolts and exhaust manifold bolts on the heads. I'd like to go with Keenserts but would like to know if this is something I can do myself. If not, any idea as to how much a shop would charge me? The exhaust threads don't concern me as much as the intake manifold threads. I want to make sure I the Keenserts are installed at the correct angle.
FYI, I stripped the threads before I knew that these heads had different bolt entrance angles than the original heads. Any thoughts, comments appreciated. Hope this was clear. Thanks.
Old Jan 12, 2009 | 02:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: L98 Aluminum head thread repair
You can do it yourself, the exact angle isn't that critical.
lt500r55
Sep 1, 2021 01:30 PM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
