Timing retarded w/ lt1 cam swap?
Old Jan 17, 2009 | 04:54 PM
crrllmich's Avatar
Car: 91 Camaro RS, 99 Camaro Z28
Engine: L03, LS1
Transmission: 700R4, T56
Axle/Gears: bunch of 10 bolts how scary is that
Ok I finaly got my 91 RS running with the lt1 cam installed. Problem is when I throw the timing light on it its showing like 10 deg. retarded? I put an aftermarket indicator on hopefully thats all I screwed up.
Any idea what else I may have done?
Old Jan 17, 2009 | 04:58 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Timing retarded w/ lt1 cam swap?
When you changed the cam, you moved the distributor. Adjust it to 0*, TDC with the timing wire disconnected and tighten the clamp.
Old Jan 17, 2009 | 05:01 PM
crrllmich's Avatar
Engine: L03, LS1
Actualy I removed the dissy and reinstalled it. I also did valve seals and what not so the motor was rotated.
So I had to set the dissy like an all new build.
Now if I try to set the timing to 0 it wont run. At 10 deg retarded it runs though. Was something possibly installed incorrectly?
Old Jan 17, 2009 | 08:23 PM
Damon's Avatar
Did you change the balancer by any chance at the same time you did the cam swap? I'm thinking your timing mark is now reading wrong for some reason (wrong balancer to match your timing tab is where I'm going with the above question). No engine will want to run at a true 10* retarded.
Old Jan 18, 2009 | 05:47 AM
crrllmich's Avatar
Engine: L03, LS1
no same balencer just an aftermarket screw on tab from summit
Old Jan 18, 2009 | 12:12 PM
Damon's Avatar
Stock balancer for a TBI engine uses a 12:00 position timing tab (seen looking straight down behind the water pump). Is your new/aftermarket timing tab in that position?
Old Jan 18, 2009 | 04:34 PM
crrllmich's Avatar
Engine: L03, LS1
No! sh*t thanks!
Now just gotta get that burning eyes fixed :-)
Where can I find the correct tab?
Linson
Oct 24, 2025 02:00 PM
RedLeader289
May 28, 2019 01:47 PM
skinny z
Oct 5, 2015 06:23 PM
Luigytico09
Oct 1, 2015 08:46 AM
92projectcamaro
Sep 29, 2015 07:07 PM
