Replacing the fuel pump
Old Jan 17, 2009 | 05:23 PM
92coop's Avatar
Car: 92 rs camaro
Transmission: 5 speed
Axle/Gears: 3.08
Re: $1000 Budget. Options?
have a 305 fuel pump went out its located in the tank is their anyway i can use a aftermarket pump without droping the tank
i have a late model 383 want to swap in place of the 305 i want to keep the tbi setup can i swap in my performer rpm 383 in place of the 305 with minor changes
Old Jan 17, 2009 | 05:37 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Replacing the fuel pump
Any pump you put on probably isn't going to like sucking through the dead pump in the tank.
Old Jan 17, 2009 | 06:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if you have the tools, dropping the tank is not really that hard. I've done it twice now and the biggest headache is usually getting the exhaust off, after that its cake.
Old Jan 17, 2009 | 07:39 PM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
or you can cut a hole out above the tank inside of car. find a junk car and cut a big piece off the metal above the tank. then cut your car a bit smaller, then r&r pump. use silicone or seam sealer with some 1/2 sheet metal screws
Old Jan 17, 2009 | 07:48 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Don't do this.
Dropping the tank is not very hard. As already stated, the biggest pain is usually the exhaust. Get the rear of the car high up on jack stands. The rear axle basically bolts right off. Drag it out of the way with a jack. You can now maneuver the tank out nice and easy. Drain as much gas out as you can before you do this so it's not heavy.
Old Jan 18, 2009 | 09:53 AM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Some touchhole did that to my car, I welded a piece of metal back in. Its purly a hack job, even you make it look nice. Then you have to cut all the fuel lines for then sender, then put rubber hose on them....If your going to do it, and care about your car, dont cut the access hole.
Old Jan 18, 2009 | 06:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
IMO, this is NOT an option, its a hack job, people who say otherwise are hacks. I would only find this an appropriate option if the car is a racecar and still using an intank pump that needs frequent servicing. One guy here did cut a hole for the replacement and did a very nice job with the whole project, so i let him slide, but i strongly feel that this is a butchery and should not be done.
Old Jan 18, 2009 | 07:11 PM
chads89ta's Avatar
Engine: 305 tpi
Transmission: t-5
i was only trying to help, he may do a great job at it but i know that is not the best way,.i have a beautiful trans am that i care of an do maintenance on, i helped a buddy do it once. and i had a junk car where i cut the panel out and is my shed, if and when my 255 pump goes out i will do this to it, then post pics of it. and yes an external pump may cost around 200 dollarshttps://www.thirdgen.org/forums/attachments/suspension-chassis/168896d1230405642-lowered-3rd-gens-pics-trans-am.jpg
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
92camaroJoe
Aug 13, 2015 06:07 AM
