1990 v6 RS engine problem
Old Jan 14, 2009 | 06:43 PM
henririchardson's Avatar
Hi
I have a 1990 v6 RS and it will start, but when I give it gas the car barley moves, it feels like it may not be getting enough fuel through the injectors or maybe there is something wrong with the engine. This happened about 24 hours ago, I started up the car and let it idle for a while, long enough for me to make a quick phone call, I started driving about 1/4 of a mile and then pulled into a parking lot to take a call, after I took that call, I pushed the accelerator, the car went normal for about a foot and then it felt like someone put the choke on, it lost all power. When I drive it, it feels like its in 5th gear or something (5th gear is an example, the car is an automatic) it does not have any rpm’s when I step on the accelerator or even when I open up the throttle manually under the hood.
…any ideas of what might be wrong?
Old Jan 14, 2009 | 07:58 PM
89T-top's Avatar
Car: 89 camaro rs
Engine: 3970014/block 350
Transmission: 700r4/shift kit
Axle/Gears: 2:73/going with 3:73's soon
Re: 1990 v6 RS engine problem
I would check the timing, maybe change the plug wires check the spark plugs, also you could run some fuel injector cleaner in it too.
Old Jan 15, 2009 | 02:54 PM
new update...the engine starts up and dies immediately
Old Jan 18, 2009 | 06:31 PM
Mic Stylezz's Avatar
uh oh this all means that you have the great v6 sickness go here and check it out https://www.thirdgen.org/forums/tech...ro-rs-3-a.html
Old Jan 18, 2009 | 07:54 PM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
It could be a number of different issues. Check your fuel pressure and exhaust system first. It could be a clogged catalytic converter, or a failing fuel system component.
plm99
Southern California Area
Nov 16, 2015 05:21 PM
HoosierinWA
Oct 7, 2015 10:15 AM
TrevinE
Sep 14, 2015 03:20 PM
Djmathis123
Sep 8, 2015 08:42 PM
Dialed_In
Aug 20, 2015 01:45 PM
