Engine build
Old Feb 20, 2009 | 05:51 PM
  #101
skinny z's Avatar
Re: Engine build
Originally Posted by v10viper04
i just redid my static compression and it came out to about 9.76 with the Dish pistons and 10.32 with Flats tops with 4 reliefs.
Out of curiousity, what specs did you use to calculate your compression ratio?
Head gasket thickness and bore,
piston deck height,
piston dish/valve relief volume,
The rest would include a 4.030 bore and 64cc Vortec heads.
Old Feb 20, 2009 | 06:05 PM
  #102
v10viper04's Avatar
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
Re: Engine build
piston deck height,
I said .018 thick gasket as ill be buying one that is supposed to be that small compressed. Deck height i used .025. dish volume i put 10.00 b/c i was told a typical dish piston is about +10.00. Did i do it wrong?
Old Feb 20, 2009 | 06:32 PM
  #103
skinny z's Avatar
Re: Engine build
Did i do it wrong?
No. Not at all.
I was looking at the 10.3:1 with the flat top pistons. I use a Speed Pro piston with 4 reliefs and my CR is 9.9:1. However I'm using a .026" thick gasket which brings the CR down a few tenths.
You'll want a fairly long duration cam to go with 10.3:1 should you go with flat top pistons.
My XR276HR gives me a DCR of nearly 8.5:1. I find that's about the limit with iron heads. Without 94 octane fuel, I have to pull my timing back and the performance goes away somewhat.
Old Feb 20, 2009 | 10:20 PM
  #104
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
No. Not at all.
I'm running 93 octane anyways so that's not a problem....
Old Feb 23, 2009 | 08:08 PM
  #105
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
I just figured out how to set my bore guage i think, i set it to read 4.030. And what i got was...... in the wear zones on cylinders 8+4 the gauge read one line to the left of 4.030. so it has a small wear i think.
Here is a pic of the one line past 0....
And here is a pic of most of the other pistons reading..... They read right about 0 and a little to the other side of the gauge, which would be under 4.030....
What do you guys think?
Old Feb 23, 2009 | 10:56 PM
  #106
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
I also figured out using this
( http://www.projectpontiac.com/ppsite/content/view/16/30)
dynamic compression ratio calculator that i will have a DCR of 8.
And no i didn't us the pontiac 350 specs lol
And that was also using the comp cams XE274 cam.
Also would it be better for a flat top with 2 or 4 valve reliefs?
Old Feb 24, 2009 | 04:02 PM
  #107
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
any ideas?
Old Feb 24, 2009 | 05:37 PM
  #108
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
Anyone? I'm trying to figure out exactly what i'm going to do... How does the bore look?
Old Feb 24, 2009 | 05:44 PM
  #109
skinny z's Avatar
Re: Engine build
Nothing inherently better with one or the other (as far as I know). It comes down to a couple of factors. Price and availability vs compression ratio difference. Seeing that a 4 valve relief piston has a minus 5cc volume ( like Speed Pro ) I can't see where 2 valve reliefs will impact things very much regarding your final CR.
Old Feb 24, 2009 | 05:47 PM
  #110
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
What about my bore measurements? What do you think?
Old Feb 24, 2009 | 05:57 PM
  #111
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
Not trying to be a pest but i really would like to finally know exactly what i need/want. Thanks
Old Feb 24, 2009 | 06:00 PM
  #112
skinny z's Avatar
Re: Engine build
I'm trying to find the out of round tolerances and maximum taper for a small block chevy and haven't found it yet. I may have to go back to my old text books to get the info.
So far from what I've seen with your dial bore gauge, I can't determine if you are within spec.
http://pantah.5starl.com/inspection/...cylinder-wear/
This web site gives a little insight into what to look for regarding those specs.
This is one of those things where you just have to be there to figure it out.
Old Feb 24, 2009 | 06:07 PM
  #113
skinny z's Avatar
Re: Engine build
Not at all.
I wish we were in the shop and going through this on the block itself. I enjoy the work , it's just difficult to work it out in a forum like this. Maybe that website link will provide a little info on what the bore gauge is capable of and what you're looking for.
Perhaps one of our engine building savy friends can provide the out of round and taper data that's needed.
Old Feb 24, 2009 | 06:09 PM
  #114
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
Man i don't understand any of that stuff, Its driving me away from wanting to even mess with the internals. haha
Its quite frustrating.
Old Feb 24, 2009 | 06:23 PM
  #115
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
I would just say screw changing the pistons and just stick with the dish pistons but idk if it will have enough compression to run properly... it will be very close if i'm calulating things right....
I wish i could just throw new pistons in there! haha
Old Feb 24, 2009 | 06:34 PM
  #116
skinny z's Avatar
Re: Engine build
Originally Posted by ljnowell
.. find a shop where you know somebody, and offer 20 bucks to a mechanic to show you how to use it. Any mechanic worth a damn should be able to use it, and show you how.
You might be at this point.
I have taken projects to local high school shops and used them as teaching aids. Any connections?
Old Feb 24, 2009 | 06:39 PM
  #117
skinny z's Avatar
Re: Engine build
That's an option for sure provided those cylinders aren't really out of whack.
I've seen more than one rebuild (a couple of mine included) that involved nothing more than cylinder deglazing and re-ringing. Can't say they lasted forever but they were reasonably durable.
Just double check your DCR measurements to make you're not building a dog.
Old Feb 24, 2009 | 08:16 PM
  #118
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
Well i figured out from one of my friends that they know a machinist who does work but is not a big business. I am going to call and ask how much for a cylinder hone. But i want to take my block to him to ask if i can just have him hone it and put new pistons in it. Basically have this guy check the cylinders to see if they are wore ok or not.
Old Feb 24, 2009 | 11:53 PM
  #119
skinny z's Avatar
Re: Engine build
Did you ever determine what the dish volume is of your existing pistons?
Old Feb 24, 2009 | 11:56 PM
  #120
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
I do not have a clue... how do i figure it out?
Old Feb 25, 2009 | 02:12 AM
  #121
ljnowell's Avatar
Re: Engine build
Assuming that you have set up the gauge right, I would venture to guess that you are going to be ok with a deglazing and new pistons and rings. If you are not showing wear at the thrust point of the cylinder walls then I would be surprised to find any taper at all on the cylinders. You do need to turn the gauge and measure 90 degrees from where you are now. You must verify that they are all still round. If they measure the same that way, I think you will be ok with new pistons and rings.
Old Feb 25, 2009 | 01:29 PM
  #122
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
I did measure crossways on the cylinder and they all same out about the same. didn't vary more than a line on the gaage either way. How do you deglaze a cylinder? Thanks
Old Feb 25, 2009 | 01:38 PM
  #123
ljnowell's Avatar
Re: Engine build
You use what the older guys would call a dingleberry hone. Its a hone that has a bunch of ***** on the end of it. Its also called a ball hone. You chuck it up in a cordless drill and use a lubricant(I have always liked using ATF) and have at it. Your goal is to break the glaze on the cylinder walls to help the new rings seat properly. The crosshatch pattern will depend on you and the speed you move the hone up and down the cylinders. I greatly prefer a dingleberry for this over the stone mounted honing tools, though that is just me.
Ball hone:
http://cgi.ebay.com/ebaymotors/GBD30...QQcmdZViewItem
Stone hone:
http://cgi.ebay.com/ebaymotors/LIS23...1%7C240%3A1318
I am not endorsing either of these specific tools, these are just for reference.
Old Feb 25, 2009 | 02:45 PM
  #124
skinny z's Avatar
Re: Engine build
They look like stock pistons. A internet search (or someone on the forum) should have the dish values. What I did find was a Goodwrench 350 that has a dished piston which looks similar to yours. With a 76cc combustion chamber it yields only 8:1. Check out this article to see how similar your build is to start with.
http://www.chevyhiperformance.com/te...ild/index.html
Here's a link to cylinder deglazing.
http://www.hastingsmfg.com/ServiceTi..._deglazing.htm
Old Feb 25, 2009 | 11:33 PM
  #125
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
Well i have a deck height of .025 i think, 5cc flat tops(when changed), .018 head gasket, 4.030 bore and 3.48 stroke. That where i got my 10.32 static and 8.09 dynamic.... That's with the XE274 figured in.
Old Feb 27, 2009 | 09:06 PM
  #126
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
Another question, changing to flat tops will i have valve clearance issues? Or does all that have to do with the lift from the cam?
Old Feb 27, 2009 | 10:02 PM
  #127
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
Re: Engine build
k, i have to say this. from the questions your asking, and the knowledge that has been given to u, i think its in your best interest to just take your shlt to the machine shop and have him tell you if you can get away with a hone.
as for clearance issues, that would be a problem if u have a big cam, witch i dont think you have to worry about
Old Feb 27, 2009 | 10:09 PM
  #128
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
I don't much appreciate the underlying message that i'm stupid, i can see that's what your saying. I am making sure i am doing this right, i'm not too brainy on the engine building side, i can fix whatever i want to, but when it comes to the complicated and touchy insides of a motor i get nervous and want to make sure i'm doing it right. Thats all.... I called a machine shop, they said $110 for a hone.... is that too much?
Old Feb 27, 2009 | 10:26 PM
  #129
Re: Engine build
not trying to be a dik, just saying it might be in ur best interests to have a pro's opinion/guidence.
110 for a hone i assume they are checking tolerances, and what not, prolly worth it. but like skinny said, this is something that u need to be guided on a personal basis, not via the web.
Old Mar 7, 2009 | 10:58 AM
  #130
skinny z's Avatar
Re: Engine build
Any progress?
Old Mar 7, 2009 | 06:34 PM
  #131
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
Any progress?
I am planning on having the bore checked and honed if its ok, If so i'll have the machine shop hone it and i'll purchase the pistons and have them press them on b/c i'm assuming they are press fit. Than i think i will have them machine the rod bolt holes to fit the ARP bolts.Thats my idea so far....
Old Mar 7, 2009 | 07:30 PM
  #132
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Engine build
cylinder out of round is .001 max
service limit .002max
taper limit thrust side .0005max
service limit .0015max
Old Mar 7, 2009 | 11:58 PM
  #133
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
What does all that mean exactly? lol sorry i'm new to the bore gauges, and reading them. Explain a little more? Thanks
Old Mar 8, 2009 | 09:52 AM
  #134
Car: 91 RS
Engine: 350 vortec
Re: Engine build
the out of round limit is .001 for a new block or one major division on that gauge you have... and is a total measured dimension. start by taking measurement at the same height around the bore find the measurement that has the needle farthest to the left of zero then move the zero to line up with the needle... that will be the smallest point of the cylinder now continue taking measurements around that height any measurement that goes past one major division to the right of zero is out of tolerance.
taper is a more dificult measurement do to the assumtion that more wear occurs on the thrust side however you can assume that the cylinder wall is straight except for the thrust side again you need to find the smallest diameter and zero your indicator then take measurements perpindicular to the thrust side done the bore the limit is one minor division for the length of the stroke
Old Mar 8, 2009 | 04:38 PM
  #135
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
Just so you know i set the bore gauge on the cylinder head to try to get it flat b/c i don't know how to hold it straight... but if you look at the picture of the cylinder gauge when i tried your idea in cylinder #4 i got 2 lines right of the 0.. and i also tried it on cylinder 7 and i got just under one line to the right.... Does it need a bore? What do you think? I think i will take it to a machine shop i'm terrible at this haha.
Old Mar 8, 2009 | 06:13 PM
  #136
Car: 91 RS
Engine: 350 vortec
Re: Engine build
it is hard for anyone to give you an answer without actually being there to take the measurement... your best bet is to take it to a shop and have it measured... if you decide that it needs a bore wait until you purchase pistons that way they can get the piston to bore clearance inspec.
Old Mar 8, 2009 | 11:13 PM
  #137
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
I also figured out my piston deck height is .035... a lot higher than i thought... Should i try to have the heads shaved a little? or will i be ok with flat tops, vortec heads, .018 inch head gasket, etc.?
Old Mar 9, 2009 | 06:55 PM
  #138
Car: 91 RS
Engine: 350 vortec
Re: Engine build
again no way to say for certain if the wrist pin sits a bit lower on the new pistons you might be in decent shape or not... however you could always have the block decked... much simpler than having the heads worked on especially if you are going to have the block honed
Old Mar 11, 2009 | 07:28 PM
  #139
skinny z's Avatar
Re: Engine build
I also figured out my piston deck height is .035... .?
I'd double check that piston height measurement.
I've been told that factory specs can be anywhere from around .025 to almost .050 below deck however I've never seen much more than .025 firsthand.
That will be a significant factor in your CR calculations.
Old Mar 12, 2009 | 06:46 PM
  #140
Car: 91 RS
Engine: 350 vortec
Re: Engine build
my first block was a 4bolt mexican block those pistons sat at .042... i was very depressed... but when i installed my scat rods and KB hyper flattops they were only .028 in the hole which worked out perfect with 64cc vortecs and a .015 gasket
Old Mar 17, 2009 | 10:43 PM
  #141
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
I am looking at this fuel pressure regulator, i am wondering what i am supposed to do about the one of the 2 outlets. Just plug one of the outlets?
http://store.summitracing.com/partde...5&autoview=sku
I am using a, in-tank TPI 350 fuel pump.
Old Mar 18, 2009 | 01:54 AM
  #142
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
I got the Block stripped finally haha
I also ordered forged connecting rods with ARP bolts already installed,ARP main bolts, Summit brand 4.040" pistons, and rings. They will be delivered tomm. (3/17/09) and i will be taking the engine to get re-bored tomorrow.
Old Mar 18, 2009 | 08:47 AM
  #143
Re: Engine build
a plug is fine, the hardware store will have them
Old Mar 18, 2009 | 08:10 PM
  #144
Car: 91 RS
Engine: 350 vortec
Re: Engine build
you need to hook up a return to the secound outlet it should say return somewhere... you dont want to just plug it as it will greatly shorten the life of the pump
Old Mar 18, 2009 | 08:21 PM
  #145
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Engine build
is the is XE274 cam?
http://store.summitracing.com/partde...&view=1&N=700+
So i have the have the rod bolt holes resized to fit the ARP bolts? And a machine shop has to do it?
Yes, thats the XE274 cam.
Not the bolt holes, but the bore of the 'big end' that fits over the crank journal. Once the bolts are pressed into the rods, that can distort the big end a bit - resizing it just 'trues' the hole, more than anything. Sorta the same idea as line honing a block.
I just noticed... that block in the pics has all the provisions and machining for a factory roller cam setup. Why not get the spider and factory type lifters (they are pretty cheap) and get a roller cam instead?
Old Mar 18, 2009 | 09:45 PM
  #146
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
B/c a roller cam is about 3 times as much as a flat tappet. With little gains over flat tappet from what i hear.....
Old Mar 19, 2009 | 02:09 AM
  #147
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
Won't it not really matter due to the fact that the reg will be downing the pressure, won't all that will be returning to the tank very low pressure? Or does it really help that much? Not judging just curious. Thanks
Also is it easier to just stick with the in tank pump then getting a FPR/guage/adaptors vs putting in a pickup line and using an external electric fuel pump that designed to be low pressure already?
Old Mar 19, 2009 | 10:58 AM
  #148
skinny z's Avatar
Re: Engine build
I would argue that point.
Old Mar 19, 2009 | 06:20 PM
  #149
Car: 91 RS
Engine: 350 vortec
Re: Engine build
the regulator will be cutting the pressure to 1 port only down to 7psi or so once that preassure is meet it needs to do something with the rest of the fuel as the pump is running constantly so the best thing to do is return it to the tank where it can be cooled and help prevent vapor lock and premature pump death
Old Mar 20, 2009 | 12:03 AM
  #150
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
Also should i go with a 600 or a 750 cfm carb? And also Are the summit brand carbs good? Or should i stick with a holley or Edelbrock?
Summit carb> 600cfm
Summit Carb> 750 cfm
Edelbrock carb> 600cfm
Holley Carb> 600cfm
