Engine build
Old Jun 29, 2009 | 09:36 PM
  #201
whatamidoing's Avatar
Car: 1986 camaro
Engine: 92 v8 5.7l
Transmission: stock
Axle/Gears: stock
Re: Engine build
[hey i just got a 1986 camaro with a 92 v8 5.7 liter engine in it . the car was running really crappy so i had to change firing order on the car it was running alot better.. but still wasnt right about a week later i discovred the smog silinoid was disconnected from the terminal where it goes into the top of the engine also the electric was not pluged into the conponent. i did some research and found out the correct way to hook it up .. i started and drove the car about 5 blocks car seamed to be running better then ever smooth and more power . after i turned the car off and tryed to start it up the next day .. car does not start .. as u hold the exnition and pump the gas the engine gets slowly to full running speed as if its running and when i let go of the exnition it turnes off as quick as i let go ?? i also tryed removing the smog silinoid back to how i org found it still same story any suggestions ?? thanks
Old Jul 1, 2009 | 12:33 AM
  #202
v10viper04's Avatar
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
Re: Engine build
Well i can tell you one thing... smog equipment won't cause your car to not start... Full tune up? Timing might be off really bad.....
Old Jul 1, 2009 | 12:37 AM
  #203
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
Also as an update.... I puller the dizzy cap off and changed to the light springs to bring the timing advance in almost fully before 3000rpms and it seems to run alot more powerful now.... I was driving in the rain (spun all the time) but its getting better! So far so good!
Old Jul 1, 2009 | 09:20 AM
  #204
skinny z's Avatar
Re: Engine build
Sounds like progress!
Watch that the springs aren't so light that they try to advance at idle. If you find your initial timing isn't stable (at idle) that would be the place to look.
Old Jul 1, 2009 | 06:43 PM
  #205
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
Alright, it seems to have good mid-range power but up top it seems to have lost some power..... I'll have to check my timing....
Old Jul 10, 2009 | 06:33 PM
  #206
Car: 1986 camaro
Engine: 92 v8 5.7l
Transmission: stock
Axle/Gears: stock
Re: Engine build
i just did all spark plugs and wires/ oil radaitor all fluids
Old Jul 10, 2009 | 06:38 PM
  #207
RamAirZ's Avatar
Car: 1999 Camaro Z28
Engine: 5.7
Re: Engine build
How about you start your own thread with your problem instead of posting this in everyone elses? This is the 2nd post in like 10 minutes in someone elses thread with your problem, you will get more people to look at it if you start your own, just an idea. Not trying to sound rude but you'll have better luck with it that way and other people will get answers to their questions as well without having to figure out which person someone is talking to
Old Jul 10, 2009 | 08:49 PM
  #208
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
Re: Engine build
WTF??
Old Jul 10, 2009 | 11:34 PM
  #209
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
Originally Posted by iroc a 86 berli
WTF??
Idk man... idk....
Old Aug 4, 2009 | 11:58 AM
  #210
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
Here's an update: I went to do a run today and i launched the car and i hit 2nd then all the sudden i head a pop noise... the engine starts to miss and a loud ticking starts.. It ran ok (based off the tone of the exhaust) but would miss every once in awhile but the ticking would obviously get faster as the rpms climbed. I drove it home (maybe 2 miles) and it was ok, didn't loose much power..... but it now sounds like a tapping. I pulled the valve covers thinking it was a rocker or something but it sounds like its deep in the block. I think i spun a rod bearing..... heres a link to the youtube vid of it running.... http://www.youtube.com/watch?v=K9aaj2Fqe0g
Old Aug 4, 2009 | 12:17 PM
  #211
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Engine build
Sounds like a spun bearing to me, but I'll admit I'm no expert on that. I would check your header gaskets. My SBC sounded very simliar when I first started it up and I thought I had a bad bearing but it was just a loose header bolt. The pop may have been a piece of the gasket being blown out of place.
Old Aug 4, 2009 | 12:21 PM
  #212
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Re: Engine build
After listening to it again on real speakers(not my crappy little earphones), I don't think the exhaust idea is right. It definitely sounds like something moving around in there that shouldn't be.
Old Aug 4, 2009 | 12:47 PM
  #213
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
I have had MANY problems with my exhaust gaskets and i KNOW its not that. I can feel the tapping through my clutch pedal when i push it in..... I think its screwed....
Old Aug 4, 2009 | 01:13 PM
  #214
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Re: Engine build
Yeah, that's not a good thing. I just got my 350 build/swap done and I can only imagine how depressing this is. Hopefully we're both wrong about it.
Old Aug 4, 2009 | 02:42 PM
  #215
skinny z's Avatar
Re: Engine build
Here's a little test I learned years ago to try to isolate a rod bearing knock.
Compare the sound of the knock with and then without the spark plug wire on the suspected cylinder. If the knock is noticably quieter, it's a good bet the bearing is done.
Old Aug 4, 2009 | 10:13 PM
  #216
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
Its too loud to be able to really even be able to tell which cylinder it is.....
Old Aug 4, 2009 | 10:24 PM
  #217
skinny z's Avatar
Re: Engine build
Do each cylinder one at at a time to see if you hear any change.
A compression test may also indicate a different problem. Blown head gasket. Bent valve.
Old Aug 5, 2009 | 02:29 AM
  #218
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
Basically what i'm getting at is i know the problem has to be in the rotating assembly as its not THAT loud up top, it sounds like its inside the block coming from the bottom end...... A bent valve can make a noise that loud?
Old Aug 5, 2009 | 05:13 AM
  #219
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Engine build
Well look on the bright side, if you catch it early enough, you dont really need any more machine work done. Just need to clean it out and throw new bearings in it. Still a lot of work, but it doesnt cost you much money, except for maybe the cam bearing tool...
Old Aug 5, 2009 | 07:15 AM
  #220
skinny z's Avatar
Re: Engine build
I'm just suggesting a couple of tests to try to confirm what the problem may be.
Try running the engine with one plug wire removed at a time. If the knock diminishes, you've found the offending cylinder and your rod knock. It's a simple test and only takes a few minutes.
Old Aug 7, 2009 | 12:15 AM
  #221
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
Also i'm trying to figure out how much it would cost to go for a 385 stroker..... Do i have to change to a better set of heads than the Vortecs? Or will they be ok in a 385? Whats a good cam for a 385? I am hoping to be at least 425hp but i would like to see 450 at the crank.... Any ideas? Thanks (and this time around i'm having a shop install the rotating assembly) lol
Old Aug 7, 2009 | 12:30 AM
  #222
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
One other thing i was thinking was changing to a roller setup (i have one from my factory L03) Is it really worth it to change to a roller setup? Or should i not bother and stick with a flat tappet?
Old Aug 7, 2009 | 02:53 AM
  #223
Car: 1992 Camaro RS
Re: Engine build
Doing a stroker means a whole new rotating assembly, clearancing the block for the longer crank throws, and checking for interference between the rods/rod bolts and the cam shaft. With Vortecs it'll knock your compression ratio through the roof. You can pull it off if you get some real deep dished pistons but I had a hard time finding some that were affordable. But i was tryign to keep it around 9.5:1.
Plus, you've got a T56... so if you want to keep your flywheel, you'll need a 1 pc RMS internal balance stroker crank. They can be had, though.
Also, I would definitely switch to a roller if you can afford it. The peace of mind is more than worth it with today's oils. And rollers give you huge performance gains. Make sure those heads can take whatever lift you throw at them though.
Old Aug 7, 2009 | 11:57 AM
  #224
Re: Engine build
you can get a 2 piece rear main crank that is internal balance to.
http://www.jegs.com/i/Eagle/356/103503750I/10002/-1
Old Aug 8, 2009 | 08:04 AM
  #225
skinny z's Avatar
Re: Engine build
Here's a 383 Vortec engine build to check out.
http://www.chevyhiperformance.com/te...ine/index.html
Old Aug 8, 2009 | 10:16 PM
  #226
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
Just based on listening to the engine i am probably going to need a new crank (as i bought a cheap rebuilt one and it was already .040 over on all journals) and the connecting rods are probably screwed as well. So i was looking at prices for engine parts and i might as well go stroker..... its just about as expensive to put a new(aftermarket) rotating assembly that it is to but a kit or the individual parts. Basically if i confused you..... 383 internal parts price is almost equivalent to say a crank/ rods etc of the stock 350..... About the same to build the rotating assembly or either one...
Old Aug 8, 2009 | 10:19 PM
  #227
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
Only other thing i was wondering as well...... I want more power out of the engine... If i stay 357 and rebuild the rotating assembly with aftermarket parts what can i do to make more hp while still keeping her streetable, Or should i go with the 383 stroker? I would have to buy a new carb/ maybe heads, etc. to see good numbers from the 383. What do you guys think?
Old Aug 9, 2009 | 01:13 AM
  #228
Re: Engine build
building a stroker motor isnt just puting in a different rotating assembly. you have to consider the block prep, as stated before there are clearance isuses with the rods to the cam and the block. a small base circle cam and grinding the block and rods while keeping it all balanced will be more money/time.
the stroker kits do make it alot easier and cheaper.
you will see better numbers when adding cubes with your current top end, jet up the carb or run a bigger one, not sure what u run. i would also rec more cam and timing. your compression ratio, will tell u how streetable it is. i street mine once in a while, its 11 to 1 with a big solid roller cam on e85. streetable comes down to what u make it, and the resources avaliable.
personally, after building a stroker, i wouldnt go any other way, when it comes to building a high performance engine.
Old Aug 13, 2009 | 01:03 AM
  #229
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
Ok i finally took the block apart and found this.....
Yea i know right? Idk how that happened but i'm going with forged pistons this time, and what a good roller cam to go with? I have the old L03 i'll pull the roller stuff out of to use... what a good roller cam to use with my current setup that's in my sig... Also i did take a good look at the cylinder walls and they seem to be Fine. Same with the head on that same side of the block.... its fine... Maybe terrible detonation or just a factory defect?
Old Aug 13, 2009 | 08:27 AM
  #230
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Re: Engine build
WOW thats ugly! I'd say detonation did it in.
With a roller cam you need stiffer springs than with a Flat tappet cam, I think you should call comp and ask them what they recommend.
Old Aug 13, 2009 | 09:24 AM
  #231
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: Engine build
Detonation or improper ring gap would be my guess.
Old Aug 13, 2009 | 11:50 AM
  #232
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
Anyone know a good roller cam to use with my setup? I hear/read rollers make more hp than a flat tappet cam.
Old Aug 13, 2009 | 02:21 PM
  #233
Re: Engine build
call a cam grinder with that question.
i used chet herbert, they custom ground a mech roller cam to my engine for $190 shipped, and its a wicked bump stick.
Old Aug 19, 2009 | 12:43 PM
  #234
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
Well for now i'm going to stay flat tappet, this friday i get paid so i'll have enough money to have everything checked over again, i might end up having to buy another crank, one of the rod faces(on the crank) does not look too good. So we'll see where it goes....
Old Aug 19, 2009 | 03:20 PM
  #235
ap72's Avatar
Re: Engine build
Those pistons are the result of detonation- which was caused by imprpor tuning. I recomend having a professional tuen you car, and a REAL professional, not a shade tree mechanic with a timing light.
I would also suggest going the roller route and the 385 route. If you need a crank and cam you're only going to spend about $300 more and have about 100 more hp- seems like an easy decesion.
ALSO, clean up the SSR, bowls, and widen the pushrod pinch in your heads, taking out 10cc's of material in each runner in the right place can do WONDERS for a set of Vortecs, don't get carried away though.
500 hp on a 383 with ported vortecs and a roller cam comes about as easy as a wet fart.
Old Aug 19, 2009 | 06:09 PM
  #236
Re: Engine build
what did u set the gap too on the old rings?
Old Oct 3, 2009 | 07:10 PM
  #237
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
Ok i got the engine running again about a month ago and it runs good, it has a little over 1000 miles on it now. My machinist informed me that it was a manufacturer defect in the piston, and that it wasn't my fault. The inside of the piston was not black at all (from the heat) it was very new and clean. But its running fine now. and i'm actaully figuring out what else i can do to the engine to pull more power out of it.(current setup is in my sig) what do you guys think? Get rid of the vortecs?
Old Oct 4, 2009 | 08:17 AM
  #238
skinny z's Avatar
Re: Engine build
It depends what your objectives are.
The Vortecs have a documented history of supporting upwards of 450hp.
If you're looking for more, then a change is in order. My only beef with the Vortecs is that they're cast iron. With my cam, I could probably stand a little more static and dynamic compression however at 10.1:1/8.1:1 I feel I'm at the limit even with 94 octane.
Old Oct 4, 2009 | 10:25 AM
  #239
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
Well right now i think my car is around maybe 300 at the wheels. I would like to see 350 to the wheels.... i want a little more out of the engine, and i do think my compression ratio is around 10:1. I did use some calculators and they come up with a little over 10:1.
Old Oct 4, 2009 | 10:44 AM
  #240
skinny z's Avatar
Re: Engine build
Here's a link to what I figure is the limit for a 350 Vortec headed small block.
http://www.popularhotrodding.com/eng...ock/index.html
You may have read it. That should give you 350 to the wheels.
If my combo gets me mid/high 12's (and that's about 300 rwhp), the sledgehammer should be good for low 12's at least.
(In my chassis anyway)
Old Oct 5, 2009 | 04:51 PM
  #241
Re: Engine build
try some nitrous out, wont be there all the time, but still gets some good power.
Old Oct 5, 2009 | 10:56 PM
  #242
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
I'll never run Nitrous.... i don't want artificial power....
Old Oct 6, 2009 | 08:23 AM
  #243
Re: Engine build
thats cool, but there is nothing artificial about gobs of power at hand.
Old Oct 6, 2009 | 09:26 AM
  #244
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
i
that's cool, but there is nothing artificial about gobs of power at hand.
Its limited that's what i don't like, its cheap horsepower... I consider Nitrous unfair power, everybody can slap a wet shot on their car and make it fast.... i would rather have the power there 24/7. I would rather beat somebody on straight motor than needing happy gas....
Old Oct 18, 2009 | 09:02 PM
  #245
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
I was wondering about S/C my car.... Buying a used serpentine S/C like most newer cars use and buy a hat thing for the carb and running the piping... What about my compression ratio? Is it too high? I have close to 10:1 compression... Would running 5-8 lbs of boost hurt it? IDK i'm just wondering about S/Cing it... Thanks
Also will hypereutectic pistons be ok to use? I heard you can with low boost and i hear you can't... any input would be appreciated thanks....
Old Oct 20, 2009 | 07:38 AM
  #246
v10viper04's Avatar
Engine: LT1, L99
Re: Engine build
I have heard both sides of the story so i would like to confirm one or the other. Thanks
Old Oct 20, 2009 | 02:45 PM
  #247
Re: Engine build
with that much compression, you are pushing the limits of forged pistons. i would not run boost with hyper's, they will destroy that engine. i have seen cars running low boost with 11:1 compression, but it was a built to the hill engine.
Terrell351
Jun 13, 2021 01:13 PM
italiano67
Dec 11, 2016 09:21 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
